LATE MODEL TRACKER GEAR QUESTIONS
  • 15 Replies
  • 4817 Views
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
« on: February 10, 2006, 08:32:22 AM »
I've got a couple questions.
1) Are the front and rear 3rd members from the earlier Tracker/Sidekicks interchangable with later model tracker/vitaras, specificly the 2.0L 4cylinder models?  I'm guessing I'd at the least need to use a 26spline front diff fron the later trackicks.
2) In which year did the kick front go from 22spline to 26spline?
3) Also, does anyone know the stock gearing on a  2000 chevy tracker 2door 4cyliner 5spd 4x4?
Offline the_maplebar
  • 466
Re: LATE MODEL TRACKER GEAR QUESTIONS
« Reply #1 on: February 10, 2006, 08:41:36 AM »
Yes.  http://www.zukiworld.com/month_030104/feature_tsb_shiftontheflyremoval.htm
4.625
Offline bzzr2
  • 1011
« Reply #2 on: February 10, 2006, 10:58:15 AM »
my 2.0L 4 banger has 5.12's, but it's an 03.... ZR2  get your VIN # and call GM's service hot line and they "should" be able to tell you exactly what's in your vehicle.
09 taco reg cab short box 4x4
  • 265
« Reply #3 on: February 10, 2006, 02:18:12 PM »
OK, so I'll need a Japanese built tracker to snag parts from....thats fine.  only one question, how many of the trackers that I see driving around in New Jersey and the surrounding area are made in Japan.  Is this going to be a fairly easy or nearly impossible hunt?  Also, if I'm reading this right I'm going to need more than just the diff for the front, mainly the diff, inner axle, and passenger CV.  Is that it?
  • 265
« Reply #4 on: February 10, 2006, 08:07:07 PM »
On e-bay all i could find are canadian built trackers (vin numbers that don't start with a js)
Offline Sidetracker
  • 30
« Reply #5 on: February 10, 2006, 09:15:19 PM »
If the vin number starts with a 2 it was made in Canada
  • 265
« Reply #6 on: February 11, 2006, 07:25:14 AM »
um, ok...still means every one I see on e-bay is a canadian.  Why can't you use a 1997-98 canadian tracker?  What did the Japanese do different?
  • 265
« Reply #7 on: February 12, 2006, 06:37:49 AM »
Come on, Someone's got to know the difference between the Japanese built and Canadian built tracker's front end
  • 466
« Reply #8 on: February 13, 2006, 09:53:33 AM »
I'm not sure what the difference is, but if you look at a parts catalog they do list some of the front end parts as being different.
  • 265
« Reply #9 on: February 13, 2006, 09:56:00 AM »
I'm just wondering if its something minor that I could work around
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« Reply #10 on: February 13, 2006, 11:27:16 AM »
The only japanese built trackers i have ever seen are 1989 and a very few early 1990
everything after 1991 were canadian built
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #11 on: February 13, 2006, 02:06:03 PM »
Sidekicks through 1995 are 22 spline.
1996 and newer are 26 spline.
Were the X-90's all made in Japan?
I know my wife's 1999 GV is Japanese, but both of my 1995 Sidekicks (2-door and 4-door) were made at CAMI (Ontario, Canada)
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline offlimits4wd
  • 76
    • offlimits4wd.com
« Reply #12 on: February 13, 2006, 05:42:06 PM »
im not sure what differences they have because i just cut the suspensions off and straight axle them but i have tons of tracker parts and i just took the complete suspension of a 2002 grand vitara limted v6 i want to get rid of
  • 265
« Reply #13 on: February 14, 2006, 09:37:10 AM »
Maybe the article is only refering to the need for the 26 spline setup.  I was under the impression that the diff housings were dimensionally the same  for all Track-kicks and Track-vits, so I should be able to swap the entire center section and passenger cv shaft from any 26 spline track-kick into my 2000 tracker.  Whats the worst thing that could be mismatched, the drive shaft bolt pattern?
  • 466
« Reply #14 on: February 14, 2006, 10:24:34 AM »
I've been looking at this online catalog:
http://www.suzukicarparts.com
It looks like the diff housing is the same between the Japan and Canada built Sidekicks.  The Passenger side CV axle assembly is slightly different, but I'm not sure what.
