Sidekick Engine Light
  • 3868 Views
Offline PT
« on: April 17, 2006, 08:59:58 PM »
I have a 1998 Sidekick Sport JLX, 146000km.  This started a little while ago <2 months.  Occasionally when you would try to acclerate it would start to hesitate and buck, but not all of the time and more often it would not do it, probably about once or twice a week.  Now, sometimes it will stall, but again not very often but is slowly getting more frequent, and is hard to get started again (kinda like it is flooded), unless you let it sit for a bit, 15 to 30 minutes.  The engine light has come on now.  This is the first time for the engine light.  It is getting looked at tomorrow, just looking for some ideas as to what could be the problem.
Offline Carnage
  • 2453
Re: Sidekick Engine Light
« Reply #1 on: April 17, 2006, 09:08:11 PM »
im not an expert
but it sounds like its running lean
did you try running the code?
(it might be the MAF)
X32...................X32CarDomainPage...................X32
[/url][/size]
« Reply #2 on: April 18, 2006, 05:42:52 AM »
I had mine running lean yesterday (no brake m/c fitted). It ran a higher idle speed and popped a bit in the exhaust but didn't stall. There are a lot of things that it could be, might be something as simple as a loose or split vacuum hose. Pulling the codes is the first thing to do and you have that in hand already.
Offline PT
« Reply #3 on: April 18, 2006, 06:15:49 AM »
According to the Suzuki dealership here in Winnipeg, the only way to get the code ouot of the vehicle is with a scanner.  Is this true.  I know that other vehicles can have the code pulled without a scanner.  My idle speed has not changed at all since I got the vehicle a year ago.
Idles at roughly 750 rpm.
« Reply #4 on: April 18, 2006, 07:39:27 AM »
  Autozone will pull the codes for you for free.
Offline PT
« Reply #5 on: April 18, 2006, 08:32:40 AM »
There is no AutoZone here in Winnipeg.
Offline PT
« Reply #6 on: April 18, 2006, 03:50:42 PM »
Thanks to all who replied.  Turns out to be an intermittent camshaft sensor.  Won't be getting the part from the dealer here though, as they want my first born for it.  Am going to look at an aftermarket.  Again, thanks to all who replied.
