Welded my front diff + other stuff
  • 0 Replies
  • 2333 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« on: May 10, 2006, 09:23:48 PM »
seeing as i have the front diff and all out, i pulled the centre and i have welded it up.
i will also weld a flange on the RHS stub axle to run 2 left hand side shafts.
i am also making some front diff lowering brackets. i will post up picks as the get made.
i have also cut the rear guards to make room for 33"s under full flex.
NOTE: make sure you tape all the wires inside out of the way before you start cutting!
i am also working on a new upper A arm design for the rear diff. can anyone help me out?
