Stock speaker size(s)
  • 25 Replies
  • 9521 Views
Offline Swedie
« on: June 11, 2006, 12:43:37 AM »
Heya!
Anyone here that can tell me what the stock size is for the speakers in the front (doors) and rear (roof)?
It's a 2001 Grand Vitara V6.
Thanks
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Stock speaker size(s)
« Reply #1 on: June 11, 2006, 07:25:39 AM »
Checked Crutchfield?
www.Crutchfield.com
Offline Swedie
« Reply #2 on: June 11, 2006, 12:54:39 PM »
Eh what the heck, couldn't find an answer anywhere... but found out now that the speakers I have are too big. But I installed them anyways... it's precisely that they fit without seeing they are too big (seiling is pushed out 1mm). They didn't fit the slots at all... but I used screws at a 45 degree angle. Should stay in. :-)
If you're wondering, I installed 6.5 inch speakers in the front and rear. Stock size are around 5 1/4th, I guess.
Oddly enough, these new "pimp" speakers sound clearer and you hear MORE of the music and beats, but have hardly any base to them at all. Fronts are 2 way with base and treble, the rear is base only with optional treble (tiny extra speakers).
Probably gonna have to install a subwoofer.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #3 on: June 11, 2006, 02:00:52 PM »
can you take some pictures?
i think my GV can get some new speakers, the oem speakers sucks :P
Offline Swedie
« Reply #4 on: June 12, 2006, 09:36:33 AM »
You don't actually SEE that there are new speakers installed, as they're hidden behind the speaker net. Oh about these nets, I am thinking about painting them black... it will give some contrast inside the car. the car is very cheap looking inside (dash, display, gear shifter knob etc).
Offline Maroon Monsoon
  • 876
« Reply #5 on: June 12, 2006, 05:56:11 PM »
should be 6.5 inch like my 2000. when I put new speakers up front it was like I never had speakers up front before so definately a great idea to do new speakers in that.. do all 4 and put the better pair up front
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #6 on: June 12, 2006, 06:58:21 PM »
what about puting in 4 good speakers? :P
  • 876
« Reply #7 on: June 12, 2006, 09:53:45 PM »
that's what I was saying, just better ones in the front than in the back. that's what I did, works great
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #8 on: July 06, 2006, 02:27:08 PM »
i got the '99 grand vitara.
is it possible to remove the rear speaker net and remove the speakers without removing the entire head lining?
i installed a mp3 player today, and now i want to install the new 6,5" blaupunkt speakers i bought.
but i don't want to destroy anything, so i gave up before i started breaking stuff :P
i hawe seen in the scervice manual, but only found out how to remove the entire head lining >:(
it can't be that complicated???
  • 876
« Reply #9 on: July 06, 2006, 08:55:07 PM »
yea, I did, I accidently kind of broke the first one and got impatient and broke the other. if you put the screens from the new ones on people don't even notice unless you point it out. the screens are intact, just would need glueing in if I really wanted to bother with it
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #10 on: July 06, 2006, 08:59:25 PM »
ok, you see...
the new screens is a little "BLING-BLING" to my taste, it has some "X" on it and looks like somthing that should be on my previous car. (Peugeot 405 ;))
  • 876
« Reply #11 on: July 06, 2006, 09:01:07 PM »
well, I am pretty sure you can glue the stock ones back in if you kind of gently twist them off like I did. just twist counter clock wise and you'll break some little plastic post and they should glue back in place... worse case scenario they don't go back in and it won't look quite as nice but the sound quality will make it worth while
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #12 on: July 06, 2006, 09:06:23 PM »
thank you, must trye that :)
  • 876
« Reply #13 on: July 06, 2006, 09:17:15 PM »
anytime
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #14 on: July 09, 2006, 12:30:45 PM »
i'm confused, tryed to remove front door panel as described in Suzuki repair manual.
it said: remove door panel by rotate 45' counter clock wise.
now i'm feeling real STUPID! how the F**K do i remove it? ???
is it a smart way to remove it or is it "the proper amount of force" way?
i must trye again tomorrow if it isn't raining.
