Installing aftermarket gagues
  • 9 Replies
  • 3657 Views
Offline gravity_storm
  • 108
  • The wino and I know
« on: August 11, 2006, 04:12:58 AM »
I've been considering adding some aftermarket gagues (volt, temp, oil pressure) to my 96 16v kick.  Can anyone tell me if there are extra taps in to the oil system and water jacket to connect to? Or do I have to install some kind of T adapters? If there are extras... can you tell me where?   ??? I want to keep all of the stock stuff functional as well.
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
Offline gonefirefighting
  • 16
  • not enough time, not enough money
    • deployment article
Re: Installing aftermarket gagues
« Reply #1 on: August 11, 2006, 01:50:56 PM »
if you want to retain use of your stock guages you are going to have to make some mods for another set. most of the time the guages are only being replaced instead of supplemented. i will dig out my service manual and see if there any alternate solutions for you guage inquiry. as for myself, i would suggest a auto meter guage replacement of your stock guages. they alot more exact than stock guages and plus look alot better. as far as mounting solutions you can modify a toyota a pillar 3 guage pod to fit your kick and will look clean without tearing up your dash.
99 grand vitara, bone stock: for now. as for my last ride?
  • 108
« Reply #2 on: August 11, 2006, 04:28:53 PM »
The A pillar mount was what I had in mind. Really the only stock gague that I would be replacing is the temp gague and I'm concerned that the computer may draw info from the sending unit. I've had the stock cluster out and there are WAY too many wires to just be the existing gagues and idiot lights. So anyway that is my long winded reason for wanting to leave the stock stuff alone.  ;D
So, care to share the story that goes along with the picture at the bottom of your signature?
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
« Reply #3 on: August 11, 2006, 06:51:35 PM »
I was running a faze temp gauge on my 8v the sensor fit in the front by the thermostat worked perfect. Then I got my 16v and swaped everything over th only prob was now the sensor will not fit. The holes are not set up the same now I am screwed. So I used some resistors in line off the stock sensor enough to set it to the wright temp works great. And just so you know the front sensor is the temp and the side is the cut off switch for the A/C if you dont have A/C you do not need it. The faze set-up has a long probe I don't know what the auto-meter has.
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #4 on: August 11, 2006, 07:10:57 PM »
i used the  coolant line to the idle air control valve
Offline CJ11
  • 157
« Reply #5 on: August 11, 2006, 08:15:06 PM »
Thats a nice set-up on the temp sensor I am off to get some parts in the morning. This way I can run them both. How does it work will it read ok or does it come in low and also where did you get all the fittings. thanks for the idea.
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #6 on: August 11, 2006, 09:54:07 PM »
it works good that line gets hot fast
Offline CJ11
  • 157
« Reply #7 on: August 12, 2006, 11:08:03 PM »
Did the mod today works great just like you said. Thanks for the help. Also what temp does your gauge run I sit at about 190.
  • 108
« Reply #8 on: August 14, 2006, 05:13:39 PM »
Hi All,
Thanks for the info. Thanks especially to safarikick for the great pics. When I get mine installed I'll post some pictures of my own.
Offline CJ11
  • 157
« Reply #9 on: October 27, 2006, 01:39:54 PM »
does any one with this mod have any problems in the colder weather. Mine seems to jump all over the place no that it is cold out let me know thanks..
