check engine light
  • 3720 Views
Offline Jecky4x4
  • 22
  • 4x4 for life
check engine light
« on: August 14, 2006, 11:19:08 AM »
Hello all,
I have a problem that my  check engine light is on all time in the panel
My zuk is: JX 1992 1.6 16V
Need help!!!!!!!
I did replace the Oxygen sensor , the engine is working good.
tanks
Jecky
Offline CJ11
  • 157
  • 95 SIDEKICK ON 31'S
Re: check engine light
« Reply #1 on: August 14, 2006, 11:57:34 AM »
look back about 3 pages there are 2 or 3 post on this one from me should help.
« Reply #2 on: August 14, 2006, 03:04:10 PM »
You might just have to push the reset button that is next to your front speaker.
I think it is there anyway, I have a 96.  :P
Offline Jecky4x4
  • 22
  • 4x4 for life
« Reply #3 on: August 15, 2006, 05:46:21 AM »
what button do you mean next front speakr
my zuk is 1992
do you  have a photo of that???
Offline nascarmanic
  • 31
« Reply #4 on: August 15, 2006, 09:59:00 AM »
Go to page 53 ( picture there )
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: August 16, 2006, 04:43:38 PM »
16v in a '92???  Is that a swapped engine?
My '96 16v was throwing an EGR code.  I replaced the EGR and no luck, turns out the tube to the EGR was clogged with carbon at the head end, as well as the passage in the head.  Cleaned it out with a wire, and the code cleared itself in about 20 miles...
Jim Z.
66 Apache camper
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: August 17, 2006, 08:50:11 AM »
Nope - 1992 was the first year for the 16V.  I had an 8-valve 91 and a 16 valve 92, before I swapped them for two 16-valve 95's...
It's not a reset button, it's a slide-switch, behind the dash.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: August 18, 2006, 05:38:09 AM »
It works like a 2-way light switch in a home, in conjunction with a switch at the odometer, this is to make the owner bring their vehicle in for service at certain milage points. When this is the problem, the codes cannot be read at all until the switch is flipped under the dash, then the dealer charges you lots of money for nothing, and your on your way. This may not be your problem, there are many things it could be, allthough EGR and the mil duty switch seem to be the most common. The best way to check is to get it scanned, if they can't scan it, it's the switch, otherwise you'll get a readable code.
Here's a pic(borrowed from the zuwharrie.com BBS) of the switch location, and I'll add the article too.
I believe this applies to OBD I (1995 and earlier) vehicles only...
The switch is visible in the Mirror and has been superimposed in the correct location.
At a given factory set milage your echoic engine light will turn on.  This is done by the manufacture to bring the vehicle in for inspection / emissions check up.
I do not currently have the milage or all the details but I do now have a picture of the magic switch.  Sometimes the location varies with in a few inches but often turning the switch to the other position will cancel the check engine light.
Bullwinkle just performed this on his 1995 4-dr 1.6L 16v.
Bullwinkle stated that his Check engine light would not blink or show any codes until the switch was flipped.
« Last Edit: August 18, 2006, 05:49:01 AM by Uncivilized »
Offline Jecky4x4
  • 22
  • 4x4 for life
« Reply #8 on: August 20, 2006, 11:46:00 AM »
Tank you guys .........
This is the  switch under the dash that  don the problem.
Whan the swich is off ,the light of the check engine go off
Tanks to all
« Last Edit: August 26, 2006, 01:29:57 PM by Jecky4x4 »
