Transfer case issues
  • 2073 Views
Offline Ratfink
  • 6
« on: September 19, 2006, 09:31:08 PM »
Now tow of my friends have Samurais. Both of them get stuck in nuetral after four wheeling. Put it in nuetral, unlock the hubs, and go to shift it back into 2wd and the stick get;s stuck and you have to take the boot off and work the shifting rids with a small pry bar to get it back into 2wd or any other gear for that matter. Happens on both so I fifure this has to be a common problem. Tries shifting it other ways too, but always the same outcome. Have to bring tools just to put it in and out of 4wd. What gives? And how do I fix it for them?
Offline Element
  • 1902
  • LillyKicker
Re: Transfer case issues
« Reply #1 on: September 19, 2006, 09:36:51 PM »
Start with the tcase sheet...
Available at Rocky Road Outfitters
Bottom of this web page
http://www.rocky-road.com/zukdrive.html
The tcase 'sheet' is the bushing your transfer case shifter rests on. It can also be one major pain in the rear when it goes bad. Your transfer case will seize up and lock into neutral. You may or may not make it home from the trail after that. Our new high-density polyurethane sheet not only replaces the factory jobber, it will also last for longer than you own your vehicle... guaranteed! Don't just get another factory bushing from the other guys, pick up our lifetime bushing and never have to worry about this problem again.
zUkTAH
U4WDA
Offline Ratfink
  • 6
« Reply #2 on: September 19, 2006, 09:41:56 PM »
Awesome man thanks. I knew this had to be common.
Offline Element
  • 1902
  • LillyKicker
« Reply #3 on: September 19, 2006, 09:49:28 PM »
It is a cheap fix, I would just do the whole shifter overhaul. This will also fix the sloppy shifter... In the transmission there is a bolt that can break along with the bushing that just breaks down and makes it treicky to shift...
zUkTAH
U4WDA
« Reply #4 on: September 19, 2006, 11:12:09 PM »
For a sloppy trans I would go with the Hawk Suzuki sloppy shifter fix.  It's cheap enough to make it worthwhile to just swap the parts rather then try to fix the stock kit.
