It's never going to happen, for one reason... Like Mike said, Suzuki wheelers are the cheapest wheelers out there. When I got my my sammy it was $700 and sprung over. I only had about $3500 (including purchase price) into it when it was taken from me. I wheel with a lot of heeps, and they couldn't believe that you could build such a capable rig so cheap. Now that I have a sidekick, I've ran into the spot thta's going to cost some money, the front end. To make the IFS strong enough to house a locker is going to require some money. So I have to two choices. Spend money on a steel third member, an anvil, and pick Mike's brain about building some custom axles, or swapping out to something different. We all have a different opinion on this. If money didn't matter to me me I would stay IFS. The ride is better than anything, and Mike's rig has proved that you can build one strong enough to last. If I ran IFS, I would run a IFS out of a full size rig and make it narrower to be closer to the width I am now. I figure if I'm going to take the time and money to do a swap, I don't want to worry about breakage. I wish I could stay IFS. But I am taking the easy way out. After all, I wheel a zuk. It is cheaper ( in the long runof broken parts) for me to go solid up front. I went through two rear axles and a ring and pinion in one summer. So I knew this winter was going to see a new rear end. One that will (hopefully) never brake. When it came time to attack the front end I decided to go solid. I chose this because I want to be as bullet proof as possible. I used the same axle that I am putting in the rear so I think my days of broken axles are behind me. To everyone here the $7000 dollers I spent in axles probably sounds high. Hell, right before I lost her, I had a set of wagoneer 44's for my sammy that I got for free. I figure I will be into the axle swap about $10k. Evryone here is freaking out by now, but if you ask a heep wheeler they will say that's a good start. It's all relative. We as Suzuki wheelers need to realize why we love them so much. Because, for $2000 you can get a sammy on 31's and lockers that will lead those expensive heeps around the woods all day. But what the heeps have on us (usually) is strength. I hate braking parts. It ruins the hole weekend. I also like to wheel my rigs hard. I can't have both if I saty suzuki running gear. Holy crap, I need to stop typing, this is giving me a headache. Bottom line is that the Suzuki universe is to cheap to ever see a good solid axle swap go on sale.
Brian
Sorry, I woke up drunk still.
