Ignition coil popping fuses...
  • 1521 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: February 07, 2007, 06:31:57 PM »
see other thread.... 8)
« Last Edit: February 08, 2007, 05:29:32 PM by Chief »
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
Re: Ignition coil popping fuses...
« Reply #1 on: February 08, 2007, 11:26:22 AM »
If you hear a "pop," I would suspect a hard short to ground.  If you measured the resistance to ground at the circuit side of the fuse, you will probably read less than 1 ohm.  I would look for a pinched wire.
« Reply #2 on: February 08, 2007, 12:03:37 PM »
Disconnect the coil and see if it still does it. That should tell you if its the coil or the wiring.
