tire pressure
  • 2940 Views
Offline RACER X
  • 383
  • zuki or die!
tire pressure
« on: June 18, 2007, 06:13:07 PM »
hey all im going to Sand Lake Oregon to ride some dunes this weekend my new kicks are BFG mud 31x10.5x15 on 15x8 rims. how low should i go on the air pressure????? i wanna have fun my gears are 538 its an automatic and i dont wanna spin a bead................. any advise????????????
98 kick
Re: tire pressure
« Reply #1 on: June 19, 2007, 12:01:25 AM »
I usually run 12 or 14 pounds, the guys I run with use 8 in their Swampers.
I say go to 14, then drop to 10 if you need more float.
450rydr
Re: tire pressure
« Reply #2 on: June 19, 2007, 11:37:00 AM »
I run 10lbs on the sand.
Offline RACER X
  • 383
  • zuki or die!
Re: tire pressure
« Reply #4 on: June 19, 2007, 05:52:22 PM »
thanks guys
98 kick
phloop
Re: tire pressure
« Reply #5 on: June 19, 2007, 06:19:37 PM »
I normally run 3 to 4 PSI, unless I am going to be driving it back and forth to work and will be only seeing pavement for a while then I wll pump them up to around 13-15 PSI.
When I ran Sand Lake, I ran 5 PSI at first then lowered back down to around 2-3 PSI. I have 32X10.50 swampers on 15x7 wheels.
Offline TysonS
  • 383
  • www.funinbc.com
Re: tire pressure
« Reply #6 on: June 19, 2007, 09:36:01 PM »
I ran those tires on the same rim in the winter here in canada in snow, useually air down to about 2psi rear and 3psi front.  Never blown a bead and I was jumping it at that pressure.
Offline W.O.T
  • 38
Re: tire pressure
« Reply #7 on: June 19, 2007, 11:01:24 PM »
atart at nine or ten psi and go from there.  if your spinning the tires like crazy drop it down to like 5 or even lower.  depends on the sand/terrain.  i have pro comp xterrains and run about 3psi in the sand.  my tires have a 6ply sidewall which is a little much for sand though bfg all terrains are much better for sand.
Offline RACER X
  • 383
  • zuki or die!
Re: tire pressure
« Reply #8 on: June 29, 2007, 09:32:43 PM »
im not sure  why this topic was moved but any how i ran 9 pnds at sand lake and did better then most 4liter jeeps i ran every dune it was great thannks to you all
98 kick
