Wheel bearing maintainance.
  • 2905 Views
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« on: June 08, 2008, 01:29:14 PM »
Well I finally replaced that pesky axle seal.
So I thought I might as well repack the wheel bearing.
Then I thought heck if I'm gonna do this side I might as well do the other side.
So after a hour and a half I'm done.
Offline Novadon
  • 205
  • South Carolina. USA
Re: Wheel bearing maintainance.
« Reply #1 on: June 10, 2008, 02:45:30 PM »
Well done!   ;)   I did mine as well! Not too bad a job. Backing off the e-brake cable for clearance and getting that funky ratchet tooth adjuster bracket set where it needs to be during brake assembly.
I posted info and pics on the "other" forum if NE1 is interested.
http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/19396-has-ne1-here-pulled-rear-axle.html
And..
 http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/20222-brake-shoe-install-lessons-learned.html
AKA, Max
« Last Edit: June 10, 2008, 02:51:23 PM by Novadon »
03' Honda Odyssey
Offline 97TRAKIN
  • 600
« Reply #2 on: June 14, 2008, 08:17:10 AM »
Did you grease the bearing with a good wheel bearing grease?
Offline Novadon
  • 205
« Reply #3 on: June 14, 2008, 09:50:08 AM »
Yep! I worked in a decent bunch by hand tween' the balls.    >:D
03' Honda Odyssey
Offline 97TRAKIN
  • 600
« Reply #4 on: June 14, 2008, 10:12:02 AM »
I'll assume you're talking about the wheel bearing *ball bearings* lol.
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
« Reply #5 on: June 14, 2008, 06:55:43 PM »
   Good assumption.
KING ZOO!!
