Technical Discussion - Beginner / Repair
rims for 30x9.5 tire?
bandit86
1641
elv8rguy
April 21, 2016, 11:07:04 AM »
How wide, what offset/ backspacing should I go with?
WVzuk
181
Re: rims for 30x9.5 tire?
April 21, 2016, 12:16:52 PM »
15x7 3.75BS
1994 4dr Sidekick: 3inch Zukination lift, 30x9.50 mud tires, snorkel, ARB rear locker, homemade bumpers
nprecon
2318
52
ONWARD... through the fog!
April 22, 2016, 04:23:14 PM »
Or... you could just mount them on your OEM stock 5.5" steel or 6" alloy rims.
'02 Chezuki Tracker with a 2 Liter and 5spd. It works for me!!!
bandit86
1641
elv8rguy
Reply #3 on:
April 22, 2016, 06:56:42 PM »
I thought about mounting it on the stock alloys, but 9.5 wide seems too wide, isn't it?
BRD HNTR
2300
56
Reply #4 on:
April 22, 2016, 10:06:22 PM »
That is what we ran on our race car with no problems. And you can air them way down.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
WVzuk
181
Reply #5 on:
April 25, 2016, 05:57:55 AM »
I had my 30 x 9.50s on stock rims and they were fine but when I switched to 15x7, the on road handling and stability was much better. Don't for 15x8 or you will loose the bead when airing down lower than 15-18psi.
bandit86
1641
elv8rguy
Reply #6 on:
April 25, 2016, 09:03:51 AM »
I picked up a ford f150 7.5 wide aluminum rims. They're quite heavy duty, if I had a lathe I'd skim a bit off to save some weight. Now to go get the tires
beagle..t
1239
16
Reply #7 on:
April 25, 2016, 06:05:22 PM »
just make sure center hole is 108mm or they wont fit over front hubs
V6 swap auto ,2 dr ,2" BL,2" jeffs kit 512 gears warn hubs and 30/9.5/15 BFG AT
