Lift kit installed. Check. Motor good. Check. Wheels and tall tires. Check. Winch installed. Check. Next up is to clean up the wiring. Looks mostly like the lights have been butchered. Enough wires under the hood for a Bald Eagle to build a nest. I'm guessing at some point the headlight switch failed, as the headlights are wired in to a separate switch. the tail lights still work off the factory switch. I have an extra factory switch. Before installing, wondering if I should go a new fuse box in place. Are any wiring harness parts available? I didn't find any when I did a google search. If not, has anyone had luck with any of the aftermarket stuff for a Tracker?
