The LJ still has the divorced transfer case, so you should be able to use any automatic transmission that has a rear output. I believe the Carry has the same drive train and the SJ-410, so that would be a good swap.
You might want to double check though, it's been a while since I looked at doing a 1.0L Turbo swap.
