Rough Running
  • 4359 Views
Offline trackermad
  • 150
Rough Running
« on: May 09, 2005, 04:25:34 AM »
Help please!!!
Ok all I need to hear some tips and ideas on what might be causing my problem.
A couple months ago my Tracker started Running rough on my way home from work.  It would idle great but as soon as I let out the clutch and put it under power it would cough and sputter like it was cutting out and then starting again.  I stoped at a store and got a can of dry gass put it in and the problem went away.  It was some time before I drove it again and when I did I filled it up and drove about 30 miles or so and the same problem popped up.  That time I noticed that if I shut it off and started it again it would run good again.  This weekend I pulled the gas tank down to repair (again) the power lines where they go into the tank thinking that might be causing the problem.  So my buddy took it to work as a test drive today (100 miles one way).  He got about 80 miles and the problem reapeared.  He is going to pick up a fuel filter today and put that in but Ive never heard of a fuel filter that will unclog when you shut the motor off.
Have any of you experenced a similar problem?  Any ideas on what might be causing it?
« Last Edit: May 09, 2005, 04:27:53 AM by trackermad »
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline SnoFalls
  • 1358
Re: Rough Running
« Reply #1 on: May 09, 2005, 06:23:10 AM »
Check the TPS (my best guess)
Any ECM codes?
Offline trackermad
  • 150
Re: Rough Running
« Reply #2 on: May 09, 2005, 06:33:15 AM »
No codes
Re: Rough Running
« Reply #3 on: May 09, 2005, 11:57:13 PM »
Clogged fuel filter can cause fuel starvation. There isn't enough fuel coming through when the engine is under load so the fuel pressure drops. When you turn it off aand back on again there is no fuel going through the engine so the pressure builds up again.
Offline trackermad
  • 150
Re: Rough Running
« Reply #4 on: May 10, 2005, 05:20:40 AM »
Ok my buddy tried to change the fuel filter for me last night but it turns out he got the wrong one.  Anyway he took the old filter off and he said the stuff that came out of it looked like tarr.  So well get the right filter today and hopefully thats it.
Keep your fingers crosed for me!!
Offline Cwkick
  • 888
Re: Rough Running
« Reply #5 on: May 10, 2005, 05:23:01 AM »
I would get 2 filters.  Change one now and in a couple thousand miles, change it again.  Hopefully you can get all of the "tar" out of the tank.
Cwkick
Offline MEDEL514
  • 52
  • Ramstein, Germany
Re: Rough Running
« Reply #6 on: October 17, 2008, 04:58:19 PM »
I'm having almost the same problem, it just started for me this past week when I started driving the car to/from work on the freeway and higher than normal speeds.  I thought I fried the injector of something, but I'll try to swap the fuel filter out and see what happens.
90' Tracker
- with some goodies
