Shocks with Coil Spacers?
  • 10 Replies
  • 4310 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« on: March 24, 2005, 01:02:54 PM »
I need new rear shocks for my 93 Tracker and I'm planning on adding 1-1/2" coil spacers. I'd like a little more travel and/or droop than stock without compromising the driveshaft slip yoke or the coil seats. I've searched the whole site and found a lot of info about crown victoria shocks, but I need to know if those would work with only 1-1/2" coil spacers or would I be better off with just stock shocks?
Re: Shocks with Coil Spacers?
« Reply #1 on: March 24, 2005, 01:56:06 PM »
   You'll want to change the shocks.  I put on the '91 Crwn Vics after my 1.5" spacers and it was a major improvement!  Might be a better option out there though, cause I'm learnin' as I go!
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #2 on: March 24, 2005, 08:57:15 PM »
any shock is better than the factory suzuki gives.
i changed my shocks about 5 or 6 times in the rear. this was with and with out spacers fitted.
anything that mounts up right will do, although some people have said that passenger/sedans shocks will not hold up to the vigors of off roading, and the constant movement through its stroke. have yet to happen to mine.
when i didnt have coil spaces, i used a shock that was 590mm extended, then put on some other shocks that were 610mm extended. with the longer shocks, i could remove the coil at full droop. not good.
i put a 1" coil spacer in and the coil was good.
then i got some other coils, which lifted the back of my vit 2", were softer than the factory, and i then put some shocks that were 630mm extended. the coil only just drops out of the top seat at full droop. very good.
i have also found that the GAS charged shocks were real stiff, and game me a head ache when i drove in town. i guess the valving was for a much heavier sedan.
then i found some factory ones off a holden commodore, the were oil filled ones, and these are the ones i use now.
i can get pics for ya in wanted.
hope this helps.
steve
and i have a soft top too. so less weight.
Offline Digger
  • 1991
« Reply #3 on: March 25, 2005, 06:14:58 AM »
How much longer are the crown vic shocks over the stock length ones? Are they long enough to allow the spring to fall out at full droop or will the 1-1/2" spacers solve that?
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #4 on: March 25, 2005, 06:16:12 AM »
Well, I went a slightly different route. I had a buddy make up some eyelet mounts, and dump the stock stud mounts. I run a rear shock from a stock 4x4 Ford Ranger rear. I have a 2" spacer, and I have the coils captured so they won't pop out, because with these shocks, they WILL pop out. Here's a pic of the mount. My dude can make these as bolt on or weld on also!
Cheesy ass flex shot! It's got a bunch more then that, and I can stuff the tire WAY up there. Need to cut the fenders more!
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #5 on: March 25, 2005, 08:37:00 AM »
when i put my bds 2" coils in my truck i used shocks for a 93 ford e150 van (rears) monroe part #32260 - they are 2" longer than a stock suki shock
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Digger
  • 1991
« Reply #6 on: March 26, 2005, 10:48:03 PM »
Thanks for the replies. Anyone else have any further info?
Offline Chief
  • 678
« Reply #7 on: March 26, 2005, 11:59:40 PM »
I got some shocks that are long enough to max out a suspension with a 2" coil spacer and not pop the coilout if you want em. They're beat up, but work, and all you have to do is pay for shipping? I think they're Monroes.
Offline Digger
  • 1991
« Reply #8 on: March 27, 2005, 04:25:43 AM »
Thanks for the offer, but I'm getting new shocks for it. Do you happen to know what vehicle they are for or what their part number is?
Offline Chief
  • 678
« Reply #9 on: March 27, 2005, 10:50:20 AM »
I think they are Monroe Gas Matic. Like 17 a piece I think. The number I got off the shock is 33097 P276W.
Offline Digger
  • 1991
« Reply #10 on: April 01, 2005, 06:16:50 PM »
I found out the answer myself tonight. At full extension, '91 Crown Victoria shocks are approximately 1-1/2" longer than stock length Tracker shocks, mount the same way and are cheaper than the Tracker shocks. I bought a pair to bolt on with my new coil spacers...
