I'm waiting for the shop to set up my gears so I can put the sami back on the road.
Some people & suppliers say the hybrid is the way to go, bigger stronger rear end and about the same money by the time your done doing just a gear swap
 Some people & suppliers say the hybrid is a waste cause you still have the same axles & they usually will break before the ring & pinion do, so you spend money beefing up the wrong stuff.
I'm of the second opinion myself, I've seen many axles give up before the gears & if the gears are toast it's usually cause the axles let go sending pieces into the gears
That's my.02, what's yours
Steve
