Well the diesel swap is done and I have the motor just about all broken in. It is sweet, I have my fifth gear back. I went with a 1.6l turbo diesel out of a VW Jetta. It is completely rebuilt and gone through. I didnt have time or the space to put it my self so I had the guys at Acme Adapters install it for me. They are also the guys who make the kit for it.
ÂÂ
The kit the make is pretty sweet, they redo the fly wheel so that it fits with the VW motor. They also make the engine mounts and an adapterplate. The cool thing aobut thier kit is that when you are done pretty much everything form the fly wheel forward is VW and form the fly wheel back in Kick. So it is easy to find replacement parts, beause there are no hybrid parts. Also if you want to put you kick motor back in you can just bolt it back into place and reuse your old flywheel.
That is a pic they sent me after they got the motor in the engine bay. I will take some newer completed ones as soon as I get some time.
For a radiator I have a 27in VW crossflow radiator with 2 12in Vintige Air fans. They are pretty cool they turn on when ever the motor get over 200 degrees and you can watch the temp gauge go back to 180. Also to keep the motor cooler we went with an Air Oil cooler. It cam out of an RX7 and it also has a thermostat so if it is too cold it will bypass the cooler. It lowers the engine temps by 10 degrees. Acme also make a GM alternater bracket, so i had them put that on as well. Even using the winch my volts stay above 12.
I just picked an intercooler off of ebay and I was told it should give me close to 20 more hp and ft lbs of torque
. I can also turn up the boost and the injector pump ot get more power as well. To do that i have to put on a pyrometer.
So far I have been very happy with it. It took a bit to get used to the different power band, but i would say that it feels like I have atleast the same if nmot more power than the Kick motor. I really like the lowend torque. It will be sweet for wheelin. I am running at about 3000 rpms at 60mph, and it doenst heat up ar all. I dont run it any higher than that. I may switch to 33s to get some of my freeway speeds back, but it isnt a big deal. I am also getting 30+ mpg
, running 32 swampers and stock gearing.
Here is the webite for Acme Adapters, check them out they have tons of info.
http://www.acmeadapters.com/index.php?sound=YHopefully soon i will be able to get it out on the trail and test it off road.
