Please login or register. May 19, 2013, 04:56:25 pm
Author Topic: Which motor does this sidekick have  (Read 3891 times)
Offline bhaugen
  • Member
  • Technical Prestige 0
« on: August 18, 2005, 06:12:05 am »
Came across a Wrecked Sidekick I am thinking of bidding on for the motor to put in my Sammy.  It is a 1995 JX 4 wd 4 dr Sidekick.  95511 miles on it.
What value is it worth.  front side damage.  Door looks like it doesn't close and the front wheel is bent out.
Offline steveofrost
  • Sr. Member
  • '91 SS JLX 4-Door
Re: Which motor does this sidekick have
« Reply #1 on: August 18, 2005, 06:40:34 am »
Do you have a VIN? They still were making the 8v in '95
Offline zaggy
  • Enthusiast Contributor
  • Technical Prestige 2
« Reply #2 on: August 18, 2005, 06:53:16 am »
Unless you ran into something real weird
     1995 4dr Sidekicks came with the 95hp 1.6/16v, basically the same bottom end as the 8v with a Single Overhead Cam 16 valve head and pistons to match....good engine, good power.
     To install where an 8v was you will need complete engine bay wiring harness and computer as well as all the little goodies you can get. Make sure you get all the fuel injection parts and wiring.
     I belive to put it in the Sammy you will need an adapter plate (build or buy), but it gives you close to a 50% increase in power.
Zag
Offline nc_zuk
  • Sr. Member
  • Back in North Carolina
    • www.samurai4x.com
« Reply #3 on: August 18, 2005, 08:40:28 am »
Definately a 16 valve motor.
It has 1.6 Liter, 16-valve, 4-cylinder, SOHC engine with Multi-Port Fuel Injection. 95 HP |removethispart|@ 5600 rpm and 98 lb.-ft. |removethispart|@ 4000 rpm.
When rounding up parts for your conversion keep in mind that '96 and up motors are OBDII and will not be smog legal for California. On '96 and up donor vehicles you will need to get the second 02 sensor portion of the wiring harness in addition to the parts listed below.
You will need the engine complete with all of the hoses, pulleys intact. You will need the fan, starter, alternator, coil, air cleaner, exhaust manifold, head pipe, engine room wiring harness, under dash wiring harness, ECM, and speedometer.
In addition to this donor parts list you will also need a high pressure fuel pump, an engine adaptor kit, and slightly taller mounts or shims for the front 4 body mounts in order to provide for hood clearance. The donor vehicles wiring harness will need to be modified for use in the Samurai as well as the Samurai speedometer which will need the speed sensor from the donor vehicle adapted to it.
In my opinion Trail Tough is your best bet when doing a 16v engine swap. They also have a special going on and the conversion kit is currently 40% off the original price ;)
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline bhaugen
  • Member
« Reply #4 on: August 18, 2005, 09:45:58 am »
Thanks Guys.  I have been looking at the local Salvage auctions for a while and this one finally came up.  We will see if I get it.  I may end up storing it for a year or so till I get to doing the swap, or fixing it good enough to drive around.
I plan on Using Trail Tough for the adapter stuff.  He definately has the most complete and you can't beat the service.
BTW VIN is 2S3TD03V6S64
« Last Edit: August 18, 2005, 09:56:26 am by bhaugen »
  • ZUKIWORLD ORDER
  • Technical Prestige 66
    • Project Turbo SideKick
« Reply #5 on: August 18, 2005, 04:09:26 pm »
Looks like a strange VIN
doesn't seem to have the right beginning
Try a free 4X4 Calculator
http://wildcatent.freeyellow.com/zookmods/calc.htm
And Chrome Don't Get Ya Home.   An armed man is a citizen. An unarmed man is a subject.
  • ZUKIWORLD ORDER
  • Technical Prestige 3
« Reply #6 on: August 18, 2005, 04:33:23 pm »
     The beginning is correct, but doesn't look like it has enough digits.  I can tell you that since it has that first S, it is not Canadian built.
  • ZUKIWORLD ORDER
« Reply #7 on: August 18, 2005, 04:39:14 pm »
Built in Spain ???
I didn't look to see where bhaugen is from
Offline 88Sammy
  • Member
    • JDM parts
« Reply #8 on: August 18, 2005, 05:14:36 pm »
LilRed is half right.  The 1st part of the Vin is correct.  The latter part is missing.
This is Canadian built.  It was built at the Cami plant.
2S3TD03V6S64
2=Cami
S=Suzuki
3=Sport Uitility
T=Sidekick/Sport
D=4wd,4dr
0=1.6L
3=Design Sequence
V=body type, SUV 4dr
6=Check digit
S=model year 1995
6=assembly plant, Cami
  • ZUKIWORLD ORDER
« Reply #9 on: August 18, 2005, 05:24:01 pm »
Ohh really, I thought there was a C in there for Canada
  • ZUKIWORLD ORDER
« Reply #10 on: August 18, 2005, 06:30:10 pm »
     Me too.  Guess they used different VIN codes for the Tracker and Sidekick even if they were both built by Cami.  Does your Kick have the S, Wild?
  • ZUKIWORLD ORDER
« Reply #11 on: August 18, 2005, 08:29:17 pm »
No mine is a J
JS4  if I remember right
89' built in Japan, with an auto
trans made in France by GM  :o
I guess the engine and axles
were from Japan tho
Offline bhaugen
  • Member
« Reply #12 on: August 19, 2005, 07:12:47 am »
I don't think they listed the whole VIN.  I went and looked at it last night and put in a bid.  Not too high.  Bids close on the 23rd at 4:00 pm.
I have been watching the salvage auctions for one for a while now and this is the first one to come up locally.
BTW I am near Fargo ND.
Offline Bobzooki
  • Web Wheeler
« Reply #13 on: August 19, 2005, 02:00:18 pm »
Yeah, that could still be an 8-valve - I believe the "JS" trim line in 1995 4-door still had the 8-valve.
JX and JLX would be a 16 valve.
I can't say this is absolutely true, because both my 95 4-doors were/are JLX trim line, and my 2-door 95 (the Gnewt) is a JX trim line.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline SnoFalls
« Reply #14 on: August 19, 2005, 03:08:14 pm »
AFAIK ... all 4dr sidekicks (not trackers) got the DOHC 16V in '92
(from consumerguide.com ... "1992 Suzuki Sidekick: Four-door Sidekicks earned a power boost, adopting a 95-horsepower engine with dual-overhead camshafts. ")
