If you are worried of the mileage, check a few things. Pop the radiator cap and check the coolant. Drain a little to see the fins inside and see how corrodid they are. See if the timing belt has been changed by looking at the bolt heads. The bolt heads should look like they had a socket on them, at least. Check the other belts condition (alt, water pump, etc.). Check the adjusting bolt heads just the same. This will let you know if it had some maintenance at least. Same for valve cover bolts. Pull the spark plugs and check the compression. This will tell you lots on the engine.
If you do go about getting it, first thing, change the timin belt, brake fluid, ps, coolant, oil, tranny, t-case, & diff fluids. That way, you have a start on the maintenance as the new owner.
I do like the color.
