sensor light
  • 1227 Views
Offline Moallen
  • 68
sensor light
« on: September 29, 2005, 11:33:01 AM »
         I changed out my dash insturments ans when I started the sammy up  the sensor light came on. I did not notice this on my other dash(light might have been out) I tried to flip the switch on the left lower drivers dide but the light goes out then comes bach on, The new odom has 65,000 miles on it. the owner manual says it come on at 60,000 miles. but whe I filp the switch it stays on.
         Where and how do I check for codes? Please help   thanks    Allen  oh   1987 samurai
1987 Samurai 32" front and rear lockers 1.6 engine spring over lift 512 gears
2005 dodge dually 4x4 diesel
98 Jeep
1989 34' Stamas twin 225
20' Sea Ark boat 1989 toyota (beater car)  two cobra kayaks 28ft classic car haul kubota L2900 tractor
Re: sensor light
« Reply #1 on: September 29, 2005, 12:14:18 PM »
You have to leave the switch in the new position for it to work.
Offline Moallen
  • 68
Re: sensor light
« Reply #2 on: September 29, 2005, 02:00:36 PM »
If I understand you , I am suppose to slide the switch to where the light stays off? When I slide it one way the light goes out when I slide it back the light will come back on and then start to flash on and off.                          Allen
98 Jeep
Re: sensor light
« Reply #3 on: September 30, 2005, 01:04:47 AM »
If it is working correctly slide it till it goes off and it should flash on for a second when you start it to let you know that the light bulb is working, if it is flashing a code you have other problems, a 12 is all is good, one blink followed by two blinks.
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: sensor light
« Reply #4 on: September 30, 2005, 02:40:18 AM »
Correct. It's like a double light switch, downstairs and upstairs, if you put the light on donwstairs it's on, but if you switch it to the other side (upstairs) it's out. Now if you put it in the position you started out downstairs its on again. Get it?
Hmmm, might be a little vague on the explanation but you got it right anyway  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
