We got away from home at 7am to arrive at the trail start around 9. Two trucks and a crew of five to cut and slash our way through the bush into our new GPS plotted track which was to join up two existing tracks.
We hopped out for a stretch and to lock our hubs in and that was when the day started going bad with Chris's RH hub on his 413 not locking in properly. I pulled it apart to find it pretty well full of crap and cleaned it the best I could and put it back on this time the knob turned around to the "lock" position problem solved - Yeah Right !
The first part of the track was to prove more slippery than I had anticipated after 300mm (12") of rain had fallen in the past 3 days. I locked up Mudfkr ARB's front and rear and made the first short climb after two attempts to a step of about 2' that I knew we'd be winching over where I waited for Chris. Hearing his 413 screaming it's nuts offÂÂ
I look over to see no drive on his front end and the eze locked rear throwing huge roster tails up - not a good sign :'(
It's was decided to just snatch him up to where I was as I'd have to winch him up the step any way as he has no winchÂÂ
Pic below.
After getting over the step we then relished we couldn't get traction on the hard slippery surface and we'd have to continue winching up until we got to the first flat area where we could get a run up for the next climb.
Pic below..
That was all good until I caught a small stump just below the surface while wheel spinning hard out and blew my RH C/V to bits, Luckily I'd left my spear at home
. I decided it would be a bit of a PITA but I'd just drive it with the front ARB locked when needed as I wasn't giving up!. At around this time Chris's 413 had regained drive to the front, hubs must of freed them selfs up a bitÂÂ
Well the first 85meters to the flat area took us just over an hour and a halfÂÂ
Where we then stopped and fried eggs on the Warn M6000 motor for breakfast, actually thats not quite true but it was hot enough to fry on !!!ÂÂ
Then we were off for the second part of the climb.
Pic below...
I got at least 30 meters before losing traction again and stopping then it hit me !!!!!!!
while I was mucking around with Chris's hubs we'd both forgotten to air downÂÂ
I was still
running 30 psi all roundÂÂ
so out with the deflater an down to 8psiÂÂ
Then I hit it again and got a bit further but still came to a holt after losing grip again. I never regained traction for the last 325mt's left of the climb so I winched the whole way to the top with Chris tied to the back of me, it only took us 4.5 hours of winching and slashing to do just over 400mt's !!ÂÂ
At the top we stopped for lunch then moved off down the other side to find a few drop offs about 20' but drivable in a ZukÂÂ
Pic below
Shortly after that we ended up coming out of the native bush on to a saddle with short scrub left over from logging native wood out in the late 60's that was to be the highest point with a good view all around so we stopped for a few pics again. Pic below
Then it was off down the ridge and back in to the native but this time on to a semi cut track from the logging era, much easier going nowÂÂ
Pic below
Coming to the end of the native we frond a few step down hills runs on a type of clay we call parpa which is like ice, hard but slippery if wet. Luckily it wasn't to wet and we only had a few moments where Mudfkr wanted to take off. Pic below
Then we get to the end where we should be able to drive to the main track in to find that the loggers had destroyed all the tracks out to the road, great no frickin trackÂÂ
A bit of spotting from the ridge and I chose my escape path ÂÂ
Not to bad going...
Dodging stumps and logging slash
Funny it didn't look that steep from up the topÂÂ
We both got down on the road OK and picked up our winch man up who had decided to walk down
then proceeded to drive home which then after 10 minutes Mudfkr decided to break the clutch cable which I had not tied back in place properly while mucking around under the hood and it rubbed through on the alternator pulleyÂÂ
Good stuff when you've got a 100Km's to get home and no clutch but you can change gear OK with out it when you have to.
Below is a shot from my new mapping program of our trail. GPS rocks
