weird idle speed with G16B
  • 14 Replies
  • 8373 Views
Offline antt
  • 49
    • Outerlimits 4x4
« on: February 26, 2005, 09:47:51 PM »
ok guys, my tracker/vitara with efi 16 valve motor has developed a weird idle pattern
when i'm pulling up to a set of traffic lights and put the put the clutch in, the revs will rise to 1600rpm, then after a second or two, slowly drop back to 800 or 900 rpm. if i blip the throttle while i'm sitting there with the clutch in, the revs will drop to 1600, stay there for a second again, then drop again to 900 or so
this happens whether the motor is warm or cold
any ideas what could be causeing it
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
Offline 3wheelerdude
  • 70
Re: weird idle speed with G16B
« Reply #1 on: February 27, 2005, 01:51:04 AM »
dirty Mass Air Flow sensor........could be something else but it worked for me.
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline antt
  • 49
    • Outerlimits 4x4
« Reply #2 on: February 27, 2005, 01:01:25 PM »
thats the one between the airbox and the engine correct?
how do i clean it? just compressed air through it or what?
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: February 27, 2005, 01:45:00 PM »
Very carefully cause if you bust it you will be spending $$$. Get some contact cleaner.
Offline cj
  • 1276
« Reply #4 on: February 27, 2005, 01:57:09 PM »
Antt, I got contact cleaner from Dick Smiths but all you need is Isopropyl Alchohol and a cotton bud but as I said be VERY CAREFUL with those wires as they are very fragile and if a wire breaks it will mean a new sensor.
Offline antt
  • 49
    • Outerlimits 4x4
« Reply #5 on: February 27, 2005, 06:48:48 PM »
thanks cj, will get onto it during the week before the comp on the weekend :)
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
Offline antt
  • 49
    • Outerlimits 4x4
« Reply #6 on: March 14, 2005, 07:23:30 PM »
ok, so i got some contact cleaner, and went to pull the mass air flow sensor out, but couldn't see these wires your on about. mine was just a plastic ball thingo that springs back and forward when ya press on it.  :-/ ......have i got the right sensor or what??? this was the one right next to the airbox...
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
mudfkr
« Reply #7 on: March 14, 2005, 07:57:37 PM »
Antt,
Theres two types, the earlier model is the springy one like yours and obviously CJ has the later model which has the exposed wire that he talks about.
Pics are always good  ;)
HTH Shane
Offline antt
  • 49
    • Outerlimits 4x4
« Reply #8 on: March 14, 2005, 08:19:19 PM »
cheers shane, yep, thats mine on the left.....so wonder if it could still be the cause of all my weird idle speed problems ???
what about the throttle position sensor? counld this be causeing it?
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
mudfkr
« Reply #9 on: March 15, 2005, 06:44:54 AM »
Could be a multitude of things Antt,
I love EFI until something goes wrong  :(
I normally start with contact cleaner in all the plugs (mine get green crap growing on them with all the
water x'ings it does) and then if that don't fix it my normal way of finding problems is to start switching parts over  which my neighbors at work (commercial wreckers) normally supply. Failing you being able to do the same I'm not much help !!
Offline antt
  • 49
    • Outerlimits 4x4
« Reply #10 on: March 15, 2005, 04:53:52 PM »
no worries mate. think i might just have to suck it up and take it to a pro to diagnose
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
mudfkr
« Reply #11 on: March 15, 2005, 06:30:35 PM »
Hey Antt,
It's not some thing to do with the high idle for the Air con is it ?? doe's it do it with the air con off ?? Just a thought  ;D
Offline antt
  • 49
    • Outerlimits 4x4
« Reply #12 on: March 15, 2005, 08:03:33 PM »
i dont have aircon, so cant be that
LWB Vitara
32in Mongrels
2in OME lift
2in Bodylift
mudfkr
« Reply #13 on: March 16, 2005, 06:11:27 AM »
I guess thats one less thing to check then  ;D
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #14 on: March 17, 2005, 04:56:55 PM »
check for any vacuum leaks - some vehicles have a valve that slows down snap throttle time - might be stuck
good luck
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
