Welcome, Guest. Please login or register.
Did you miss your activation email?
September 09, 2010, 06:25:00 PM
Login with username, password and session length
Forum is fed to Twitter.
Search:     Advanced search
208221 Posts in 23513 Topics by 12569 Members Latest Member: - blackzuki01 Most online today: 676 - most online ever: 1307 (November 04, 2009, 10:28:54 PM)
Pages: 1 [2]
Share this topic on FacebookShare this topic on MySpaceShare this topic on DiggShare this topic on Twitter Topic: Q&A - Lake Tahoe, CA., Rubicon Trail - POSTPONED -  (Read 4850 times)
ROSS
ZUKIWORLD ORDER
Technical Prestige 0
Offline Offline
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
« Reply #15 on: April 25, 2007, 07:45:56 PM »
try a practice run somewhere local.  maybe a couple hills up and down.
maybe a couple of quick brakes.   try it out and see
Element
Enthusiast Contributor
Offline Offline
LillyKicker
« Reply #16 on: April 25, 2007, 07:49:52 PM »
Thats what I am going to do... My Father in law has a small lighter tandem axle trailor, I will put brakes on it and test it out...
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
RHodge
Offline Offline
« Reply #17 on: April 29, 2007, 12:50:47 PM »
I can see why poeple drive diesel trucks , I was figuring out how much fuel I would use, I figure about 230-250 |removethispart|@ 3.20 to 3.50 a gallon by then   Lips Sealed
Ryan
Hutch
ZW Staff
Technical Prestige 2
Offline Offline
ZUKIWORLD Staff
WWW
« Reply #18 on: April 30, 2007, 01:22:35 AM »
I have comtemplated this scenario many many times. I was going to get a new GV to replace my pickup. the GV towing capacity of 3000 lbs is right about a sammy flat towing set up ( A bit more for my sidekick) but you will be using the GV for all of the braking and the big tires have alot more rolling resistance.
So if you found a light weight trailer with brakes it should roll better and it won't fry your brakes coming down the hills even if it is a bit over 3000.
I think I would probably do the trailer route and take my time. I flat tow my sidekick and it pulls great flat towing behind my ram. I usually flat tow if the trail is easy or less than like 2 hrs away. If it's further I rent a trailer from united.  (I figure if I break something major I can run home and get parts(or a trailer) if it's only 2 hrs away. 3 hrs and more just sucks!
My plan is to by a newer toyota tacoma. More HP, torque and towing capacity (6500lbs) than my 99 ram 1500.  plus it gets better gas mileage.
Pages: 1 [2]
ZUKIWORLD Online | Your Suzuki Enthusiast Community Forum  |  ZUKIWORLD Events and Activities Forum  |  ZUKIWORLD Adventure Series  |  ZUKIWORLD Adventure Series Q&A 2007 [ARCHIVE]  |  Topic: Q&A - Lake Tahoe, CA., Rubicon Trail - POSTPONED -
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
©2000-2010 ZUKIWORLD online by Specific Hazard Unlimited L.L.C. All photography and content by ZUKIWORLD online unless otherwise noted. Send all comments, suggestions, or questions about this web page to the editor. All rights reserved please view our terms and conditions before use.
