Reiter Trails, WA - July 5 2008 - Crawlers NW
  • 2453 Views
« on: July 07, 2008, 02:00:33 AM »
Some shots from a club trip up to Reiter on Saturday. It was surprisingly empty out there, we only saw two other groups running around other then a stray TJ we found about half-way through the day.  A lot of the local crowd probably headed over to Eastern Washington this weekend though.  The rain was on and off for most of the day and made things a bit slick for those without lockers on both ends.  :D
We had 3 Zuki's on this run.  My SJ-410.  Steve, club members 88 1/2 Samurai with a Dana 44 front and Ford 9" rear, and my Dad's 93 Tracker with the rear locked up on 30" tires.  The Tracker is now in need of rear spacers though, as the flexing from the last few trips has helped the rear springs flex enough to start sagging down a bit.  Rounding out the group is a club members FJ-40 and the before mentioned TJ on 32" tires we picked up.
Full pictures are on-line at http://picasaweb.google.com/CrawlersNW/ReiterTrailRunJuly5th08.  A video compilation will come eventually.
This will probably be the last trip for a little while.  Thee is a plan to head back to Eastern Washington sometime in August, no idea if I will have time to go play before then.
« Last Edit: July 07, 2008, 02:04:56 AM by Drone637 »
Re: Reiter Trails, WA - July 5 2008 - Crawlers NW
« Reply #1 on: August 06, 2008, 12:45:47 PM »
Finally got around to putting a Video on-line as well.  :)
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
« Reply #2 on: August 06, 2008, 10:32:34 PM »
Nice pics. Look us up on wazuks.com if your planning a trip back up here. Theres some that play at Evans and Elbe most weekends.  Group runs coming up for Rim Rock also.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
