Suzuki Autos Only (not - 4x4)
Aerio SX and Aerio Sedan
(Moderator:
ebewley
Aerio TSB's
Aerio TSB's
hcgalvin
1695
Roads? Where we're going, we don't need roads.
Aerio TSB's
October 27, 2006, 01:16:08 PM »
Here's a list of all the current TSB's
Title: Drivetrain and or Suspension - Abnormal Rear Tire Wear
http://www.alldata.com/tsb/Suzuki/1132646400000_1135238400000_TS05/
Title: Keyless Entry System - Inoperative Using Transmitter
http://www.alldata.com/tsb/Suzuki/1031727600000_1049270400000_TS02/
Title: Engine - Ticking Noise
http://www.alldata.com/tsb/Suzuki/1039593600000_1049270400000_TS02/
Title: Brakes - Metallic Clacking and or Clicking Noises
http://www.alldata.com/tsb/Suzuki/1039593600000_1054537200000_TS01/
Title: Cooling System - Correct Coolant Usage
http://www.alldata.com/tsb/Suzuki/1041926400000_1074758400000_TS02/
Title: Audio System - Static and or Electrical Noise from Speakers
http://www.alldata.com/tsb/Suzuki/1043913600000_1054537200000_TS01/
Title: Steering and or Suspension - Alignment Designation Update
http://www.alldata.com/tsb/Suzuki/1044259200000_1054537200000_TS01/
Title: Steering - Popping Noise on Slight Turns
http://www.alldata.com/tsb/Suzuki/1048752000000_1054537200000_TS02/
Title: Engine - Repeat Rear Main Seal Replacement
http://www.alldata.com/tsb/Suzuki/1052290800000_1054537200000_TS03/
Title: Wipers and or Washers - Washer Nozzles Leak Fluid
http://www.alldata.com/tsb/Suzuki/1056092400000_1056956400000_TS02/
Title: Recall - Poor Windshield Mounting Adhesion
http://www.alldata.com/tsb/Suzuki/1056524400000_1056956400000_TS03/
Title: Emissions - EVAP Canister Purge Valve Service Revisions
http://www.alldata.com/tsb/Suzuki/1057906800000_1060239600000_TS02/
Title: Manual Trans - Service Manual Updates
http://www.alldata.com/tsb/Suzuki/1078041600000_1081234800000_TS01/
Title: Brakes - Front Brake Pad Applications
http://www.alldata.com/tsb/Suzuki/1083913200000_1085554800000_TS02/
Title: Instruments - Partial or No Cluster Display
http://www.alldata.com/tsb/Suzuki/1084777200000_1085554800000_TS04/
Title: Manual Trans - Left Driveshaft Pops Out of Final Drive
http://www.alldata.com/tsb/Suzuki/1088406000000_1093590000000_TS02/
Title: Charging System - Battery Discharge at Idle
http://www.alldata.com/tsb/Suzuki/1088578800000_1093590000000_TS03/
Title: Drivetrain - Differential Bevel Pinion Mounting Distance
http://www.alldata.com/tsb/Suzuki/1089442800000_1093590000000_TS01/
Title: Lighting - Headlamp Installation and or Alignment Revisions
http://www.alldata.com/tsb/Suzuki/1097564400000_1099987200000_TS05/
Title: Engine Controls - VIN Registration After ECM Replacement
http://www.alldata.com/tsb/Suzuki/1098342000000_1099987200000_TS04/
Title: Engine Controls - DTC P0420 and or P0430 Manual Update
http://www.alldata.com/tsb/Suzuki/1099987200000_1103529600000_TS05/
Title: Instruments - Left Hand or Right Hand Door Mirror Loose
http://www.alldata.com/tsb/Suzuki/1103011200000_1108454400000_TS06/
Title: Keyless Entry - Remote Transmitter Inoperative
http://www.alldata.com/tsb/Suzuki/1103184000000_1108454400000_TS02/
Title: Auto Trans - Correct Torque Converter Bolt Usage
http://www.alldata.com/tsb/Suzuki/1107158400000_1108454400000_TS04/
Title: Cooling System - Aerio - Coolant Identification and or Usage
http://www.alldata.com/tsb/Suzuki/1111824000000_1112598000000_TS02/
Title: Cooling System - Aerio - Correct Coolant Usage
http://www.alldata.com/tsb/Suzuki/1113462000000_1115794800000_TS02R/
Title: Steering and or Suspension - Alignment Specification Revision
http://www.alldata.com/tsb/Suzuki/1113462000000_1115794800000_TS03/
Title: Engine - Aerio - Main Bearing Oil Clearance and or Selection Revision
http://www.alldata.com/tsb/Suzuki/1116313200000_1118818800000_TS04/
Title: Suspension - Aerio - Clunking Noise From Under Vehicle
http://www.alldata.com/tsb/Suzuki/1117695600000_1118818800000_TS04/
Title: Engine - Aerio - Serpentine Belt Chirp or Squeal
http://www.alldata.com/tsb/Suzuki/1120114800000_1122620400000_TS05/
Title: Brakes - All Models - Normal Operational Noises
http://www.alldata.com/tsb/Suzuki/1130310000000_1131350400000_TS01/
Title: Engine Controls - MIL ON and or DTC P0441 Set
http://www.alldata.com/tsb/Suzuki/1132732800000_1135238400000_TS06/
Title: Engine Controls - MIL ON and or DTC P2025 Set
http://www.alldata.com/tsb/Suzuki/1133856000000_1135238400000_TS07/
Heather Galvin
