93 Tin top tracker
  • 47 Replies
  • 20355 Views
Offline vw505
  • 133
93 Tin top tracker
« on: March 02, 2011, 08:29:51 PM »
I just picked up a 93 4x4 auto hardtop tracker. My plans are to take the lift out of my wrecked 96 soft top 5 speed and swap the diffs for the 5.12 gears and run some 30x9.5's. I will post some pics if i ever get off work before 7pm.
Offline vw505
  • 133
Re: 93 Tin top tracker
« Reply #1 on: March 05, 2011, 04:47:24 PM »
started working on it today. I got the rear lifted with my 4door spring and Zuks spacers. I am looking under the dash now trying to find the nag switch to shut off the check engine light.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #2 on: March 07, 2011, 01:08:47 AM »
It's there, trust me.  I just found it on one of my Trackers behind that little dash panel under the steering column.  That was the only thing activating the light.  I knew that's what the problem was when disconnecting the battery wasn't resetting the battery, and I couldn't flash the codes.  Once I found the switch and reset it, the CEL shut off.  OOOH MAGIC
Glad you're able to put those parts to good use!  I'd like to see pics of what's going on.  You know where to find me if you need some other parts...
Offline vw505
  • 133
« Reply #3 on: March 07, 2011, 09:07:02 PM »
I think it was by passed. i un-hooked the batt. and the light has not come back on after starting it.
Offline vw505
  • 133
« Reply #4 on: March 10, 2011, 07:22:57 PM »
Offline vw505
  • 133
« Reply #5 on: March 10, 2011, 07:24:41 PM »
this is it with 4door springs and 2" spacers in the rear. I may be take the spacers out if i cant safely run 2" spacer up front with 4door springs
Offline djlantis57
  • 871
« Reply #6 on: March 10, 2011, 09:13:17 PM »
Wow nice find man.  93 is the last year of the tintops too.  Good job on the lift
Offline vw505
  • 133
« Reply #7 on: March 10, 2011, 09:22:58 PM »
There is 2" more lift in the front now> I think i my go with a 1 or 2" body lift or mode some diff. brakets so i dont blow out my cv's >
« Reply #8 on: March 11, 2011, 06:35:23 AM »
If the code never came back after disconnecting the battery, you just cleared the code (whatever it was).  It was not the mileage code.
Nice clean looking tin top.  Did you invert the strut mounts?
Offline vw505
  • 133
« Reply #9 on: March 11, 2011, 09:24:22 PM »
i have spacers in the front. I just got my tires mounted and will put them on tomarrow.
Offline djlantis57
  • 871
« Reply #10 on: March 11, 2011, 11:36:39 PM »
I can't remember...just how bad was the other one wrecked? Anything still usable?
Offline vw505
  • 133
« Reply #11 on: March 12, 2011, 12:25:53 AM »
Oh ya, a bunch, i can get in it and it starts right up. 4 wheel drive is 100% . Just the damage to the right side was more then i wanted to put in to it.  I want to pull the gears this weekend if i can.
« Reply #12 on: March 12, 2011, 05:46:41 AM »
Mine must be incredably rare since it's a 95 tintop! 8)
Offline djlantis57
  • 871
« Reply #13 on: March 13, 2011, 01:40:39 AM »
Doh bentparts you got me!! That's right. I believe the tracker tintops were through 95 but the sidekicks cut off the tintops after 93. Thanks for the reminder  ;D although bentparts yours IS the ultra super rare turbocharged model  :laugh:
« Reply #14 on: March 13, 2011, 05:46:01 AM »
Thats right buddy and don't you forget it :laugh:
