DIY Steel Front Axle, Tracker/Sidekick.....replacing a weak link.
  • 10 Replies
  • 15739 Views
Offline heiney.5
  • 175
  • 9
« on: September 28, 2010, 10:22:46 AM »
Offline heiney.5
  • 175
  • 9
Re: DIY Steel Front Axle, Tracker/Sidekick.....replacing a weak link. pt 2
« Reply #1 on: September 28, 2010, 10:23:01 AM »
  • 6593
« Reply #2 on: September 28, 2010, 11:07:28 AM »
Excellent in-depth post.
Thank you for sharing!
« Reply #3 on: September 28, 2010, 11:13:58 AM »
X2
Wow!! Thanks!  I appreciate all the effort you put into sharing this!!!
« Reply #4 on: September 28, 2010, 08:18:21 PM »
Very detailed, and good photo's.  This is the best axle conversion thread I have seen.
Great job.
« Reply #5 on: October 07, 2010, 04:44:30 AM »
A+ Great Job!
Offline heiney.5
  • 175
  • 9
« Reply #6 on: October 07, 2010, 06:42:09 AM »
Thanks for the kind words....
I do have a question some of you may be able to answer:
If you have a Calmini Anvil, will the front skid plate fit?     It seems all the pics I have seen of the Anvil don't show a skid. Maybe this is just to "show-off" the Anvil.
Like mentioned above, my clearance is tight between the skid plate and axle. Since this axle is STEEL, I'm debating running no skid....maybe truss/enforce it (needed?).  Any thoughts?
« Reply #7 on: October 07, 2010, 12:53:16 PM »
Excellent write up  :)
« Reply #8 on: October 08, 2010, 06:57:45 AM »
I ran a skid plate to keep from getting hung up on stumps and large rocks (that is on the Race Car now).  I will have another one made when I am able to run trails.  The steel is stronger, but there is not much clearance for the gears, and a small dent will have the ring gear rubbing,  (I had to remove a dent to keep from rubbing when I built mine.)
Offline heiney.5
  • 175
  • 9
« Reply #9 on: January 29, 2016, 06:57:55 AM »
|removethispart||removethispart|@ ebewley ..... you know what happen to this post? Not sure why it would be lost....again....
Offline Toys-n-Joys
  • 91
« Reply #10 on: May 09, 2020, 08:04:57 PM »
|removethispart||removethispart||removethispart|@ ebewley ..... you know what happen to this post? Not sure why it would be lost....again....
Wondering the same thing
