project tracker 2 door sas build
  • 47 Replies
  • 17192 Views
Offline joe dirt
  • 148
Re: project tracker 2 door sas build
« Reply #15 on: April 19, 2010, 09:51:36 PM »
 here is the plan for the rear...as stated above im having issues getting the rear the same as the front...instead of cutting off the mounts and rewelding them lower,...was thinking of using the front spring mount with a piece of 2x4 tube as a spacer to achieve the 4 1/2 difference in height...also this would give me more to help capture the coil springs over stock....
whatcha think??
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
Offline joe dirt
  • 148
« Reply #16 on: April 19, 2010, 09:53:41 PM »
couldnt sit around doing nothing...so i drank a few more beers and made the decision to just weld the home made spacer in ther....no going back now...id have to say...it set damn near perfect now...here are a few pics of how it set now...
Offline joe dirt
  • 148
« Reply #17 on: April 19, 2010, 09:54:53 PM »
some before and after pics of the custom spacer...
Offline joe dirt
  • 148
« Reply #18 on: April 19, 2010, 09:56:01 PM »
and a mug shot....with the kid resting on my shoulder ??? ???
Offline joe dirt
  • 148
« Reply #19 on: April 19, 2010, 09:59:45 PM »
ok,...your all caught up to date,...sorry if this build looks like it was done in just a few min.,..i just copied and pasted from my original build,..ill keep ya posted of what im doing,...right now im working on little stuff,....like shock towers, brakes, steering, gussets, etc...ill get pics of all the little stuff as well,...thats the kinda stuff that seems to be missing in most of the build threads out there,...trust me,...ive probly read every sas thread out there for these...lol
Offline rascott
  • 669
  • 15
« Reply #20 on: April 19, 2010, 11:28:52 PM »
thanks for the write up. real nice work!
i note the original post dates- you really powered on this project!
Offline joe dirt
  • 148
« Reply #21 on: April 20, 2010, 09:50:02 AM »
thanks,...this is actually my daily driver...i need to get it finished as diesel prices are geting high,...i need to park my lifted powerstroke!!!
  • 6594
  • 68
« Reply #22 on: April 20, 2010, 10:24:35 AM »
Cool! Thanks for posting up the pics and descriptions.... Very cool...
+1 TP
Eric
« Last Edit: April 20, 2010, 10:27:47 AM by ebewley »
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #23 on: April 20, 2010, 11:14:20 AM »
It's looking good, I'd like to see the rest of it.  Nice idea using the front spring cups and a spacer for the rear.  Cheap is good, free is better  ;)
If you eventually plan on doing a Samurai case and 2wd trans, then would you swap the rear axle too to match the offset of the Samurai case?
« Reply #24 on: April 21, 2010, 01:47:23 AM »
I say stick with the suspension lift, but you should probably check out what your driveline angles are going to be like in the rear before you make a decision.   Great looking work though!
Offline joe dirt
  • 148
« Reply #25 on: April 21, 2010, 09:06:20 AM »
built the top link spacer last night, but i didnt like it "stepped or staggard",..so ill be moving the rear bottom links a tad lower and longer to center the wheel in the wheelwell,..after i do that ill be able to cut and extend the top link as well and not have to stagger the spacer,...by the way,...spacer is about 5" tall,...and made from super strong reciever stock...its going to have to due untill i can afford to do a complete link system in the rear
Offline joe dirt
  • 148
« Reply #26 on: April 21, 2010, 11:10:59 PM »
changed my mind,..ill extend the links later and use this,..im getting impatent!!!
its built from reciever stock and staggerd 2 1/2"..4" tall
« Reply #27 on: April 21, 2010, 11:32:22 PM »
Are you going to add a brace that bolts back to the top of your axle for extra strength?
Offline joe dirt
  • 148
« Reply #28 on: April 21, 2010, 11:45:29 PM »
i was looking at a easy way to weld a few tabs to the top of the diff and to the back of the spacer,..then just bolt on the "stabilizer" to the top of the diff...i dont like the spacer at all but im sure that will help ease my concerns
Offline joe dirt
  • 148
« Reply #29 on: April 22, 2010, 08:55:10 PM »
well dug around in the shed and found a complete set of billstiens,...not sure what they came off of but he end piece looks like jeep,..fully extended they are 24" long...
so me being a cheap bastard,..i cut the ends off the stockers and modified these billstiens with the stock ends...now i dont have to go but rear shocks!!!
