Sammy Project
  • 34 Replies
  • 12767 Views
Offline Hillbillydave
  • 213
Sammy Project
« on: April 12, 2009, 05:46:16 AM »
And yet another Sammy build!!
Plans include
SPOA
Sidekick rear axle with 5.12's welded
34x9.50 mudders
Twin stick
Roll cage
Isuzu Rodeo springs on rear
Rear up front (possibly Rodeo up front as well)
Custom bumpers
Other fun stuff not thought of yet!
I don't work fast so, this might take a while!
'89 sidekick 1.3L 3" blue suspension parts, custom strut extensions 31x10.5 Mud Trac's on 10" rims rear fenders trimmed, lincoln locked rear, Rochester Carb on custom adapter
93 Sammy project, SPOA with 34's, 5.12's, welded, in the works
Offline Carnage
  • 2453
Re: Sammy Project
« Reply #1 on: April 12, 2009, 09:47:34 AM »
so wheres the write up?
  • 213
Re: Sammy Project
« Reply #2 on: April 12, 2009, 10:52:36 AM »
I'm a little ahead of the game on posting, sorry. I was able to work on it yesterday. I installed a right front fender and removed the dash. Did some horsetrading as well and ended up with a windshield fold-down setup from an SJ410 and a set of modified door hinges so the doors can be easily removed. These came with doors still attached, so I traded my doors (which were in better shape) for the doors with the removeable hinges.
Hopefully today I can get the front axle and dummy case removed.
I will post some more pics later.
Offline Carnage
  • 2453
Re: Sammy Project
« Reply #3 on: April 12, 2009, 01:57:58 PM »
well, once you get something done be sure to post em up immediately!
dont make us wait!  lol
 8)
Offline bama jama
Re: Sammy Project
« Reply #4 on: April 12, 2009, 05:58:06 PM »
Good plan David. If you need any help let me know! Bill
Bill,'88.5 Tin Top.Project (just got)        '91 2wd bought new,1.6 4v, weber,Calmini header,neon seats,TJ flares.
  • 213
Re: Sammy Project
« Reply #5 on: April 12, 2009, 06:25:43 PM »
I'll try not to make ya'll wait too long!
Thanks Bill! We will be talking to you soon...gotta come see that tin top!!
Picked up the Rodeo springs today, will get some pics tomorrow.
Here are a couple of pics from this afternoon.
First two pics are of new fender, third pic is the interior minus dash.
« Last Edit: April 12, 2009, 06:28:20 PM by Hillbillydave »
Offline bama jama
Re: Sammy Project
« Reply #6 on: April 12, 2009, 10:01:39 PM »
You've been busy Dave. See you got those hard screws out. I may have the part between the fenders the grille mounts to if you need one. I'm thinking about a 410 grille for the tt. Bill
  • 213
Re: Sammy Project
« Reply #7 on: April 14, 2009, 05:14:05 PM »
Thanks Bill! I'm not sure which way i will be going with the grille area.
Well I got the rear end dropped this afternoon. Gotta love those two wheel drives! Sure makes it easy when a vehicle hasn't seen a lot of mud! Here's a pic of the two springs for comparison. The Rodeo spring is on top, Sammy is on the bottom. As you can see, the new spring is not centered. If installed as shown, it will set the axle back two inches. But reversed it will offset close to four inches. Still debating...
Memory card was full, and it was getting dark...will take more pics later.
  • 213
Re: Sammy Project
« Reply #8 on: April 16, 2009, 06:33:02 PM »
Well, I got some more stuff done. Rear bumper is removed. Looks like I am gonna mount the spring so I have the four inch offset. I realize that is gonna mean extensive trimming, but I went into this project with that in mind. Gonna have to use missing link shackles in the rear, might try to make some at work tomorrow, if I have time. Will have new pics to upload by the weekend.
Offline bama jama
Re: Sammy Project
« Reply #9 on: April 16, 2009, 07:38:42 PM »
Man Dave, your moving on. Dibs on the bumper. I got my yj flares on and cleaned up the Sam. Got to finish up this '91 so I can get busy on the TT.  See ya,Bill
  • 213
Re: Sammy Project
« Reply #10 on: April 18, 2009, 07:38:27 PM »
Well I had to do a quick mock up today. Temporarily mounted axles back under the sammy just to get an idea what it's gonna look like and to get an plan on the missing link for the rear. These are not the tires I am gonna run, they are the 31's from my sidekick. I have a set of 34x9.50's that I have to pick up. Finished ride height will probably be a little higher, since I have not got the rear springs mounted. Gonna be a good bit of trimming(cutting?) in the rear...
  • 213
Re: Sammy Project
« Reply #11 on: April 20, 2009, 07:19:46 PM »
Mocked up my missing link rear shackles today. Looks like I need to add about 2 Inches to the horizontal part.
Offline bama jama
Re: Sammy Project
« Reply #12 on: April 20, 2009, 07:24:19 PM »
Looks good Dave. I found a 1.6 short block if you are intrested. Bill
  • 213
Re: Sammy Project
« Reply #13 on: May 03, 2009, 06:33:11 PM »
Been busy with work and other stuff, not much progress except for removing the fender flares. Here is a pic as it sits now.
Re: Sammy Project
« Reply #14 on: May 05, 2009, 05:00:13 PM »
Looks good sitting there.  Are you going to flat fender the back then remove the gas tank next?
