SAS 1994 Geo Tracker
  • 13 Replies
  • 10190 Views
Offline MrBracket
  • 53
    • moto-mule.com
« on: August 03, 2010, 08:52:54 AM »
Here are some pics of my current project.
I started with a lifted 2wd 5spd Tracker:
Offline MrBracket
  • 53
    • moto-mule.com
Re: SAS 1994 Geo Tracker
« Reply #1 on: August 03, 2010, 08:57:36 AM »
Then I got out the sawzall and grinder....   ;D
Offline MrBracket
  • 53
    • moto-mule.com
« Reply #2 on: August 03, 2010, 09:04:09 AM »
Then I added a samurai t-case with 4.16:1 gears in it,
a front axle out of a Jeep Wagoneer
a rear axle out of a Jeep Cherokee Chief
both axles have ARB air lockers and 5.13:1 ring and pinion gears
Sky manufacturing High Steer Kit
Toyota IFS steering box
straight 4 link suspension with panhard bars
Air bags for springs
and a bunch custom brackets, they don't call me Mr Bracket for nuthin...  ;)
« Reply #3 on: August 03, 2010, 10:23:29 AM »
Nice looking Tracker...
Offline c10long
  • 39
« Reply #4 on: August 03, 2010, 11:05:14 AM »
nice build.  You have any pics of the suspension and how you mounted it?
Offline MrBracket
  • 53
    • moto-mule.com
« Reply #5 on: August 03, 2010, 11:56:29 AM »
I didn't do a very good job of taking build pics on this project....
Here is one picture that should point out some of the details.
Offline c10long
  • 39
« Reply #6 on: August 03, 2010, 01:30:30 PM »
Right on.  Just asking because i know there's some interest in different ways of making a 4 link suspension.  how'd the front mounting work out?  same as rear?  thanks
Offline MrBracket
  • 53
    • moto-mule.com
« Reply #7 on: August 04, 2010, 07:26:19 AM »
Yes, the front is a mirror image of the rear.  I even made the links all the same length, well the lowers are the same front and rear as are the uppers.  Obviously the uppers are shorter than the lowers...
I only used rubber bushings on the ends of the links for now.  Wanted to test out the suspension before investing in flex joints.  It turned out better than I thought, the pic of it all flexed out above is with rubber bushings.  When the rubber bushings wear out, I'll invest in some nice flex joints.
Offline MrBracket
  • 53
    • moto-mule.com
« Reply #8 on: August 04, 2010, 07:59:43 AM »
Here are a few more shots of the suspension setup.
« Reply #9 on: August 05, 2010, 01:32:50 PM »
are you running a pan-hard bar in both the front and rear?
Offline MrBracket
  • 53
    • moto-mule.com
« Reply #10 on: August 05, 2010, 02:35:03 PM »
Yes, it was actually "more" important on the front, as the steering would try to push the axle side to side.  With non triangulated links like this set up, you have to run pan-hard bars or the axles can move side to side.
Offline joe dirt
  • 148
« Reply #11 on: August 07, 2010, 07:43:13 PM »
i saw the "orygun" plates..where ya from?..im in portland/gresham...good choice on color...lol...heres mine
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
Offline MrBracket
  • 53
    • moto-mule.com
« Reply #12 on: August 08, 2010, 05:11:35 PM »
How funny! My son swore that I had to have the only Big green geo around!! Looks good man!!  I live down in the Eugene Area.
Offline allout
  • 41
« Reply #13 on: August 08, 2010, 07:33:46 PM »
Nice work. Looks familiar LOL
94 Tracker, SAS with YJ's, spartan locker front , welded rear, 33/10.50's, 4.24tcase gears, Warn M8000. Toy axles being built up.
