sidekick turbo diesel build (then rebuild)...picture thread!!
  • 74 Replies
  • 21067 Views
Offline Jluck
  • 1389
  • 40
Re: sidekick turbo diesel build (then rebuild)...picture thread!!
« Reply #15 on: August 17, 2010, 08:56:48 AM »
here is what I scored for my coolant plumbing. some prototype five layer one of a kind silicone one piece hoses that a local vw guy had built. WAY COOL. soooo much cleaner than the multi fitting and 13 hose clamp abortion that was before. 8)
~deeprecon1 this is what I did, if you look close at a earlier pic I trimmed the driver side MM and added metal to the bottom of mount to replace any integrity that may have been removed~
  • 6577
  • 66
« Reply #16 on: August 17, 2010, 10:54:59 AM »
Thanks for sharing! +1 TP
Offline Jluck
  • 1389
  • 40
« Reply #17 on: August 17, 2010, 09:24:35 PM »
got my water pump today. and what I learned....there are two types available one complete assy. with a cast iron impeller and just a bolt into housing type with a funky stamped sheet metal impeller. vw shop I deal with says the latter type have a "extremely" high failure rate.  :o
Offline Jluck
  • 1389
  • 40
« Reply #18 on: August 17, 2010, 09:32:10 PM »
to be able to fit the oversized silicone hoses and to avoid the mess of elbows and hose clamps needed with the acme kit I did some mods.
1) cut front flat part of motor mount (above the bend to minimise loss of integrity)
2) added material to open bottom of mount to replace what I cut out (and left a drain slot at lowest point)
« Last Edit: August 30, 2010, 01:16:25 PM by Jluck »
« Reply #19 on: August 17, 2010, 09:42:34 PM »
Ya it looks like we need to hire a hose guy ! lol
I am fed up with the crazy hose clamp action really ...
J now you are making me feel self conscious about not making my motor look all pretty ! .... damn you
Living the Dream in Communist California
2002 vw golf tdi 300k miles 47 mpg avg
1988 vw1.6td  suzuki samurai trail blazer
Offline Jluck
  • 1389
  • 40
« Reply #20 on: August 17, 2010, 09:52:37 PM »
I think its time to rethink that mount, why not make it underslung or something. there is gotta be a better way, its f-n ridiculous as-is
« Reply #21 on: August 18, 2010, 05:32:31 PM »
I said F $#% it Im building hot and cold side manifold ... I hope it works  ???
Offline Jluck
  • 1389
  • 40
« Reply #22 on: August 18, 2010, 10:34:45 PM »
well here's my progress for the day. 8)
here you can also see the finished plumbing
« Reply #23 on: August 19, 2010, 03:36:35 PM »
Looks good.  Any idea what the specs are on the new engine compared to the stock 1.6L?
Offline Jluck
  • 1389
  • 40
« Reply #24 on: August 19, 2010, 03:51:53 PM »
I will be sending my pump to Giles in Canada when I can find an extra 1k laying around, when I get that back I should have a 110-125 hp   175-250 tq motor (estimate)(but collaborated guess with Gilles) >:D
also have my turbo at bell turbo to work his magic. (don't know if that will gain much, just cant boost a IDI motor much) >:D
Offline Jluck
  • 1389
  • 40
« Reply #25 on: August 20, 2010, 08:57:50 PM »
well waiting on snail mail to deliver more under hood stuff figured I would see what else I can f#*k up on my 'kick... I cannot get the rear axles out they are a PITA! got a bigger slide hammer will try that when hands heal. :'( (and yes I took off all the nuts!)
Offline Jluck
  • 1389
  • 40
« Reply #26 on: August 24, 2010, 10:38:04 PM »
spools in, twin sticks are in time to tear down the front and regear 8)
more on the diesel soon....(waiting on parts)
Offline Jluck
  • 1389
  • 40
« Reply #27 on: August 26, 2010, 10:42:11 PM »
well progress is slow. I borrowed my father in laws tractor to use on the house I'm having built soooo.....you know what its like to borrow somethin from family, 3 hours of use and BANG!!!! goes the front hub....FYI john Deere parts are more expensive than Suzuki parts >:(
any way all I had time to do was mount the oil filter, I had it in a very bad place before. now it looks better I will just have to clean my engine bay at oil changes..
it fits really nice in otherwise unused realestate
what do you think ??? any better ideas??
Offline Jluck
  • 1389
  • 40
« Reply #28 on: September 02, 2010, 10:43:49 PM »
well, not alot of time to tinker with the 'kick but hers a couple current pics, got a few odds and ends done on 'er but nothing major.....BTW, I think I am going to rebuild the injection pump my self and save a ton of cash. and hopefully be off the road by hunting season.
Offline trackermatt91
« Reply #29 on: September 12, 2010, 08:42:24 PM »
you should mount a drip pan under the filter so it doesnt mess all over your inner fender after every change.
matt
