FS: Complete 1.6L 16V Turbo 'Kit'
  • 2994 Views
« on: August 10, 2012, 03:51:19 PM »
For Sale:
1 x IHI RHB5 VJ 119002 in great condition (no shaft play)
1 x IHI RHB5 VF 48706 with a little shaft play (does not come close to hitting sides)
Yes ... that's two turbos ...
1 x Sean DeVinney exhaust manifold
2 x High heat exhaust gaskets
1 x Exhaust manifold to down pipe gasket
2 x Intake plumbing
1 x Exhaust down pipe plumbing
2 x Heat shields
1 x Oil return line
Looks like the pics were deleted :( but if memory serves, I purchased the generation setup after this one (or it was this actual kit?): http://www.zukiworld.com/forum/general-suzuki-forum/turbozuki-1-6-16-valve-5-hour-junkyard-turbo-setup/. The two RHB5s are VERY similar, but there is a small difference in blade pitch on the input and output sides (tuned to the original manufacturers specs of whatever engine they were OEM for). I just-so-happen to have both, so you can play and see which you like best, or have the second unit as a backup (which is what I was going to do). There should be life left in the second turbo, but it will need a rebuild eventually. To have someone rebuild the IHI was around $100 back when I was looking & the economy was better ... might be cheaper now ... or you can be a freak like me and DIY it on the cheap.
Aeromotive Fuel Management:
This kit is for anyone that really wants to tune their turbo system. I have fuel management module, 125psi fuel pump, plumbing, regulator, wiring harness, mounting brackets & manual I got off fleabay.
NOTE: the fuel management + pump alone, without harness / fuel lines / regulator, are a $500 value
I need money more than I need these parts, and I'd rather keep things 'in the family' so I'll sell EVERYTHING HERE for $800 + actual shipping from 95833 (50 - 60 lbs). I'll have these parts listed elsewhere, but I'm trying to sling them on-the-cheap here. I prefer to sell this as a complete kit, but I'm open to reasonable offers that won't effectively make the rest of the kit un-sellable.
Re: FS: Complete 1.6L 16V Turbo 'Kit'
« Reply #1 on: August 13, 2012, 06:28:30 PM »
Sale pending ...
« Reply #2 on: August 17, 2012, 05:53:58 PM »
Is this kit still available?
« Reply #3 on: August 18, 2012, 03:35:32 PM »
SOLD!
