Sidekick / Tracker multi-switch, turn signal / wiper switch assembly
  • 12 Replies
  • 5157 Views
Everything works. Does not have cruise control option. I replaced mine with a new one and done need this one floating around. $15 plus shipping. It should fit in a flat rate box.
Offline carolinarigman
  • 33
Re: Sidekick / Tracker multi-switch, turn signal / wiper switch assembly
« Reply #1 on: December 02, 2018, 09:07:56 PM »
1998 and older? If so and you take paypal, I'll take it.
If shipping to 27522 doesn't require a bank loan. ;D
« Reply #2 on: December 03, 2018, 08:58:06 PM »
Carolinarigman - PayPal is fine.  I won't be home for a few days. It might fit in a large flat rate box. I won't be home to measure it until Thursday morning. I think a large flat rate is $16 or so.
  • 33
« Reply #3 on: December 04, 2018, 03:15:14 PM »
That sounds fine.Which end of our world do you live? :)
I'll take it. when You get home is fine.
Maybe you can answer a question.
Are the wire terminal ends the same
between a Cruise and a non cruise control?
Thanks!! Have a good trip!
« Last Edit: December 04, 2018, 03:17:18 PM by carolinarigman »
« Reply #4 on: December 07, 2018, 03:38:24 AM »
I have the switch in my truck and go to the post office today. The connectors are the same, except cruis has an additional connector.
The long sub harness that goes from left to right under the dash has the two additional connectors, for the cruise on/off and rear window wiper/spray.
  • 33
« Reply #5 on: December 07, 2018, 08:28:03 AM »
Ok sounds good. Let me know a total and Your paypal and I'll send Ya' some cash!
Thanks! Doug
« Reply #6 on: December 07, 2018, 06:02:30 PM »
It wouldn't fit in a flat rate box. I need to get a box that will fit. It should be about the same shipping fee. How much of a rush are you in. This is a non cruise switch, BTW.
We are having heavy rains, so I didn't go back out.
  • 33
« Reply #7 on: December 07, 2018, 09:40:28 PM »
No big rush. Just let me know the total and I'll send to your paypal.
You can ship whenever you get the opportunity. I've got a long way to go
before needing it. Even if after Christmas would be fine.
PM your paypal and the cash will be on the way.
Your a regular on here a lot. So I trust you, no problem!! :)
« Reply #8 on: December 12, 2018, 05:18:13 AM »
It's all boxed up. I'm going to PM you for you address, etc.
  • 33
« Reply #9 on: December 26, 2018, 03:22:30 PM »
I've received the switch. Hope your money is there!
Thanks! Doug
« Reply #10 on: December 26, 2018, 03:50:59 PM »
I'm glad that it made it.
  • 33
« Reply #11 on: December 26, 2018, 06:38:48 PM »
[/quot
You get your money?
« Reply #12 on: January 05, 2019, 11:48:16 PM »
Yes it made it. I'm looking forward to seeing your build.
