31'' will fit with out any body lift???
  • 1622 Views
russian
« on: November 26, 2008, 01:57:28 PM »
does anyone know if it is possible to put 31'' on stock 1994 tracker (2 door lsi convertible) with out doing body lift to it.....or does it need any other mods to fit them???
Re: 31'' will fit with out any body lift???
« Reply #1 on: November 26, 2008, 03:46:04 PM »
  You will need some kind of lift either suspension or body 30 x 9.50 rub with front and rear bumper covers off on stock wheels.  Scott
« Reply #2 on: November 26, 2008, 04:16:47 PM »
Either that or plan on doing a lot of cutting.  You can probably cut back the fender well to give you enough room.
Offline rascott
  • 669
  • 15
« Reply #3 on: November 26, 2008, 04:29:17 PM »
i did a "body lift" on my '89 kick.
 just swapped out the lower body mount doughnuts for a rubber shim and added that much rubber on the other end
gave me |removethispart|@ 1 1/8" over stock.
 with a(jeff's ?) 2" lift, 31's work.
probable rubbing without more lift.
« Reply #4 on: November 27, 2008, 07:45:50 AM »
Sawsall?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: November 27, 2008, 02:49:13 PM »
You can fit a 31" tire on 7" wide(not 8") wheels with a 2" - 2.5" suspension lift and some inner fender trimming. Street driving only - no heavy wheeling.
Offline JayN
  • 220
« Reply #6 on: November 28, 2008, 12:32:26 PM »
i had 31's on mine with nly some small coil spacers and samurai wheels.
then added some body lift and put 33's on it.
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
