1.6 8v distributor woes
  • 1517 Views
Offline smitty808
  • 76
  • Hit it with your purse???
    • Godzuki!
« on: January 02, 2006, 02:35:48 PM »
Ok when it comes to the old Samurai carb, and ignition system, I am a master! But I now bow down to the mighty Track/Kick gurus for help with this problem!
We are going to do a 1.6 swap into my Nephew's samurai. We bought a donor(1991 4 door Sidekick) from a friend...and he bought it from another friend ::) The first guy had it running, and said it sounded good. He had to swap the dist from his truck to get it going. The second guy has embarked on throwing parts at it, and never got it running. It has no spark. Power at the coil, and the module on top oif the coil bracket.
Guy one said the guy he got it from had changed the dist module, and it never ran again. With his it did though. I saw something on here while searching that said the modules don't interchange between years....how can you tell them apart? are there tests to see if the module is good? I read something about 4 pin, and 3 pin modules??? All of the info is kinda' vague though.
I work on motorcycles for a living...I mess with electronic ignition, and FI every day, but 2 dozen people have been jacking with this thing, so it's hard to tell where to start.
I want to hear it run in the Sidekick before I pull it to swap.
250000 miles...and still going! http://www.godzuki.us[/url]
The Bedford Boys!!
http://www.balls-deep4x4.com[/url]
Offline zaggy
  • 1134
Re: 1.6 8v distributor woes
« Reply #1 on: January 02, 2006, 02:57:07 PM »
If it was me I would get the poor thing on to TDC #1 and start from scratch and assume nothing.
To many fingers in the pie
Zag
Offline smitty808
  • 76
    • Godzuki!
« Reply #2 on: January 02, 2006, 03:16:25 PM »
Will it not even spark if it's not timed right???
I thought it would spark...just at the wrong time?
The Bedford Boys!!
Shilly
« Reply #3 on: January 02, 2006, 08:43:45 PM »
Maybe a fried ECM?  I also agree with Zag about too many thumbs in there already...  :-\
Offline takai
  • 907
« Reply #4 on: January 03, 2006, 05:43:18 PM »
When in doubt. Doubt everything  ;D and start from the beginning. Test and Retest if neccessary. Best of luck.
'Cause, I am to misbehave.
