1.6 8V to 1.8 16V swap
  • 1 Replies
  • 1501 Views
Offline chet
  • 556
  • Zuki time!
« on: May 09, 2006, 08:44:45 AM »
I have a line on a sidekick sport. I did a search and it answered a few questions. The trannys are different so I will need to use the tranny with the 1.8.
The frames are wider on the sports so what motor mounts do I use?
Wiring? Will I have to do a complete dash/wiring harness swap? Also what about the air bags and ABS? I really don't want the ABS but If I have to swap axles as well then I will. Swapping to air bags is def out of the question!!
Do the sports have bigger brakes and axles than my '91 4 door?
Offline Yoak
  • 577
Re: 1.6 8V to 1.8 16V swap
« Reply #1 on: May 09, 2006, 09:49:13 AM »
You can get a cusom flywheel and use stocky tranny.
You will need dash harness and ecu, modify it with your existing one hence abs/bags won't be an issue, don't wire them up (they won't work anyway..well not without some work
