1.6 conversion
  • 1838 Views
Offline BigRedSamuri
  • 31
1.6 conversion
« on: January 16, 2006, 05:26:52 PM »
i am planning on putting in the 1.6 into my sami bc i blew the 1.3 and want more power. i was wondering if my sami trans is a direct bolton to the 1.6 or will i have to buy an adapter?
Offline takai
  • 907
Re: 1.6 conversion
« Reply #1 on: January 16, 2006, 06:31:56 PM »
You will need an adapter. You will also have to use the 1.6 starter and alternator. You should be able to re-use your manifold and exhaust.
'Cause, I am to misbehave.
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
Re: 1.6 conversion
« Reply #2 on: January 16, 2006, 07:45:39 PM »
run a search here and on bbs.zuwharrie.com and you will find tons and tons of info.
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Re: 1.6 conversion
« Reply #3 on: January 16, 2006, 07:51:48 PM »
 call hawk, or trail tough. there is a little more involved than a bolt in.
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
Re: 1.6 conversion
« Reply #4 on: January 17, 2006, 06:21:25 AM »
If you have the $$$ and can find a complete 16valve 1.6L, its very worth going to Trailtough, getting the wiring harness&adaptor kit (along with an electric feul pump) and doing that swap.  I LOVE THE 16valves power and will NEVER EVER run a carb again.  Also trailtoughs support is AWESOME and the harness made everything ultra easy.
Offline billybob
  • 23
Re: 1.6 conversion
« Reply #5 on: January 17, 2006, 09:00:23 AM »
Personally I opted for the Petroworks adapter kit...ya, it's a little more expensive but it's got thr ultra strong circular motor mounts and the kit lowers and tilts the engine just a bit to clear the hood without the need for front clip body lift.
Do your research... TT does have the deal on the harnesses tho'
billybob_CA
Offline takai
  • 907
Re: 1.6 conversion
« Reply #6 on: January 17, 2006, 06:20:26 PM »
They are actually running a special on the Harness and Adapter Kit through the end of January. About $200 off the normal price.
