Can't figure this out???
  • 1 Replies
  • 971 Views
Offline fullspectrum
  • 16
  • behind the 8 ball
« on: September 19, 2006, 03:26:28 PM »
I recently finished my spring over on my 86 Sammy. Everything is fine in 2wd but in 4wd I have a vibration and a little clicking coming from the front end. Before the spring over there was no clicking in 4wd/2wd. Also it's very hard to put it back in 2wd after driving a little in 4wd (It's like somthing is binding and I have to sort of force it back into 2wd). I tried lifting the front wheels off the ground when this happened and the wheels kind of turned back like they released the binding. After this it went back into 2wd easy. WTF is causing this?
Just to clairify I have fixed hubs and no driveshaft spacers yet. All perches were welded on parallel to old ones. Spring are stock all around. I tried to lift the wheels and spin everything looking for binding and all appears to be fine. What am I missing??? :-[
"Beer is living proof that God loves us and wants us to be happy." - Benjamin Franklin
"Whether you think that you can, or that you can't, you are usually right." - Henry Ford
Offline kymike
  • 87
Re: Can't figure this out???
« Reply #1 on: September 19, 2006, 05:36:18 PM »
check your u joints and make sure your drive shaft is indexed
