Where can I find find one inch fender flares for our Tracker?
  • 7 Replies
  • 3641 Views
Offline RalphARoni
  • 83
« on: January 12, 2020, 02:11:53 PM »
Our 96 2dr is basically unmodified but the tires are a couple of inches wider than the original and stick out a bit less than an inch. Sometimes I want mud and it has to get on the roof even but in day to day riding  I dont. I saw these $30 foam self stick ones but they look crappy and easy to tear. Nothing else I can find looks like it would match up. Has anyone found any? I'll use 3m tape to hold them on if I find any.
'96 Geo Tracker 2 dr auto 4wd 15" wheels, 23" tires, named "GT" and towed behind the motorhome
Offline ROLLOVR
  • 30
  • U.S.A. Lawn Gnome Liberation Front TN. Chapter
Re: Where can I find find one inch fender flares for our Tracker?
« Reply #1 on: January 13, 2020, 01:56:10 AM »
Low Range Off-Road has a set you may want to look at.
Pricey but possible the best option.
http://www.lowrangeoffroad.com/1989-1998-suzuki-sidekick-tracker-2-door-fender-flares.html
Warning; Do not drop acid and go Gnoming, For lest ye think thou are the Glorified Messiah and Savior of all Gnomes.
Equation ( Dropping Acid + Lawn Gnoming = A Visit from the Man )
Offline RalphARoni
  • 83
« Reply #2 on: January 14, 2020, 07:01:40 AM »
Look serious! I have to see if they make it in a one or perhaps 2" option. I might want to put them on with em foam tape to avoid making holes though. I'll do some checking.
« Reply #3 on: January 14, 2020, 07:27:22 AM »
They also offer this style in a 2.25" size.
Offline RalphARoni
  • 83
« Reply #4 on: January 14, 2020, 03:10:34 PM »
I think I would like that better. I'll check it out. Thanks
« Reply #5 on: January 16, 2020, 11:16:18 AM »
I used a set of 3" JC Witney flares.  Drill and rivet every 4 inches, works pretty well.  If I had the time I would take off the inner plastic liner and weld a 1" lip on the inside of the fender well to give a bit more purchase.
Offline RalphARoni
  • 83
« Reply #6 on: January 20, 2020, 04:24:27 AM »
This looks like it would suit me fine. I would put them on with the 3m tape that holds the solar on our RV so no holes. I looked on JC Whitney and could not find them. I am sure I will pass a JC Whitney  sometimes in my travels though and if I can find them. Thanks
« Reply #7 on: January 28, 2020, 01:22:15 PM »
They may not sell them anymore, it's been quite a few years since I bought any and I usually picked up a box from a swap meet.  :D
It does look just like a generic kit from Amazon.
https://www.amazon.com/Pacer-Performance-52-189-Reinforced-Extension/dp/B00029X0ZG/ref=sr_1_11?keywords=ez+flares&qid=1580246444&s=automotive&sr=1-11
