1.8L ???
  • 1561 Views
1.8L ???
« on: August 08, 2009, 03:23:52 PM »
I've been looking but havent found much, do you guys have any idea what performance parts are available for the 1.8L?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: 1.8L ???
« Reply #1 on: August 08, 2009, 07:55:36 PM »
Not much - if anything - is available for the 1.8.
It had a short life and was replaced by the 2.0 and later engines.
I understand that, if you did not use 10W30 engine oil, the timing chain system will fail.
Sean DeVinney at afermarket4x4.com is your best source of info on this engine.
Ack
Re: 1.8L ???
« Reply #2 on: August 08, 2009, 08:26:59 PM »
Thanks for the info ack, I appreciate it. Will 2.0L swap in easily?
Re: 1.8L ???
« Reply #3 on: August 10, 2009, 03:52:30 AM »
Reportedly, the 1.8L and 2.0L are the same "family". I've read about a guy swapping in the 2.0L and claiming the wiring harness / ECU from the 1.8L handled it just fine.
  • 4327
Re: 1.8L ???
« Reply #4 on: August 10, 2009, 05:48:34 AM »
This is something I'm curious about - I'm seeing the 1.8 described as both a J18 and a G18.  The J series and the G series are distinctly different engines, so either there are two 1.8s or there are a lot of confused people.
Re: 1.8L ???
« Reply #5 on: August 10, 2009, 07:59:56 AM »
I wouldn't doubt it. The Swift & Tracker engines are the same but different too. I believe the metro engines had stronger internals, different intake / exhaust (for transverse mount), and dizzy. Same bolt patterns though.
