1.8L Temp sensor location?
  • 1 Replies
  • 1725 Views
« on: February 12, 2010, 11:24:12 PM »
Can anyone verify the location of the temp sensor on the 1.8L motor? The 1.6L location is not the same.
I see some sort of sensor behind the exhaust manifolds but I would like to confirm its location. Thanks
Re: 1.8L Temp sensor location?
« Reply #1 on: February 13, 2010, 10:39:09 AM »
I believe it's on the back of the cylinder head (outlet elbow actually) between the engine and the firewall - look from the right side (not the exhaust side) and you should find it.
The sensors on the exhaust side are ...
- cam position sensor - at the back of the cylinder head
- O2 sensor - on the manifold
- oil pressure sender - on the block under the manifold.
