10 bolt or 12 bolt??
  • 10 Replies
  • 2866 Views
« on: July 04, 2003, 02:18:44 AM »
What year the the Kick/Tracker switch to the 12 bolt rear carrier? I found a couple of low mileage Kicks (96,97) in a local yard that are going to be scraped, and they will sale the carriers cheap.
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
Re: 10 bolt or 12 bolt??
« Reply #1 on: July 04, 2003, 06:37:51 AM »
I am under the impression it was 1994 and up.
Mac
  • 6589
« Reply #2 on: July 05, 2003, 11:15:17 AM »
I think it was '90. For sure 96 and 97 will have 12 bolt carriers...
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #3 on: July 05, 2003, 04:43:45 PM »
According to Calmini's website for there LSD it is 94-98 for the 12 bolt and 89-93 for the 10 bolt. Speaking of are the axles the same length, could I swap out just the pig and the axles or would I have to swap out the whole rear end.
Mac
  • 6589
« Reply #4 on: July 06, 2003, 03:14:04 AM »
Mac
You wouldn't need to swap out the axles. All Sidekick rears are 26 spline. Some of the later model ones, especially 4 door models, are a little bigger in the middle and the 97,98 models have a 5 bolt [instead of 4] outer flange but they are all widdled down to a 26 spline.
So, find a 12 bolt carrier and put it in! :)
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #5 on: July 06, 2003, 08:16:33 AM »
That makes life way to easy!!!
Thanks Eric
Mac
Offline 1bigtracker
  • 3409
« Reply #6 on: July 30, 2003, 05:06:00 PM »
94 and under are 22 spline.  i'm pretty sure
« Last Edit: July 30, 2003, 05:06:47 PM by 1bigtracker »
  • 6589
« Reply #7 on: July 31, 2003, 02:01:31 AM »
In the rear, Sidekicks have always been 26 spline. The fronts have been upgraded from 22 to 26 over the years.
Offline 1bigtracker
  • 3409
« Reply #8 on: July 31, 2003, 09:05:32 AM »
O, my bad. Sorry bout that
Offline Natebert
  • 1098
« Reply #9 on: July 31, 2003, 09:55:58 AM »
Our 95, 4dr is a 12 bolt, 26 spline unit.
(had it under close inspection when putting in the 5.12s the other day)
Offline ZeusZuki
  • 411
« Reply #10 on: May 03, 2005, 12:23:20 PM »
You may find the rear axles are longer too. Over here in New Zealand we get "wide body" Escudo's ( Kicks ). The rear axle assembly is 40mm wider to match the 40mm wider body set up. Just do a measure up against your diff housing and all will be revealed. The later model flanges are part of the axle and five bolt ( your wheel bolts directly to the axle and not the brake drum ). The earlier axles are four bolt and you bolt your wheels to the drum assembly on these ( five bolts on the drum ). All rear ends are 26 spline - 410/413/sammy/kick's.
ZeusZuki.
