10 bolt R&P question??
  • 15 Replies
  • 3160 Views
95XL7
« on: August 04, 2004, 11:09:38 AM »
Are the pre 94 10 bolt front and rear ring & pinions the same? I mean if you order them do they have the same part# ?? and can you use the front in the rear carrier?
Offline idaholwb
  • 772
Re: 10 bolt R&P question??
« Reply #1 on: August 04, 2004, 04:29:50 PM »
 None of the trackick front and rear dropouts won't interchange. You can't use the front in the rear, and vice versa. At least in a kick. In a sammy, if the front was a 26 spline, you could swap both ends.
97 Sport
265/70-16s
2" lift
2.0 swap
95XL7
« Reply #2 on: August 04, 2004, 11:31:29 PM »
No you didn't understand. I am just talking the ring & pinion sets themselves,not the whole member. ;)
« Reply #3 on: August 05, 2004, 12:09:58 AM »
I think they are different, I will have a look tonight
  • 6589
« Reply #4 on: August 05, 2004, 02:19:58 AM »
They are different. The rear ring gear size is 7.5" inch and the front is 7". Not sure on the actual numbers but I know they are different. Anyone got real numbers? Hagen would know. :)
Offline Bfunk
  • 406
« Reply #5 on: August 05, 2004, 03:36:42 AM »
I've got a set of rear ring and pinion gears if you need them.  They are the 5.125s.
Brian
« Reply #6 on: August 05, 2004, 05:01:51 AM »
Just had a look with the tape measure. Rear (10 & 12) are 7.5", front is 7".
95XL7
« Reply #7 on: August 05, 2004, 10:08:40 AM »
Brian
thanks for the offer but i'm looking for 5.38's or 5.62's. Gonna end up getting some from a 89 1.3ltr i guess.
the 5.38's would be nice but i only seen them for Sami's.
  • 6589
« Reply #8 on: August 05, 2004, 10:51:01 AM »
What about the 5.83:1 aftermarket gears?
95XL7
« Reply #9 on: August 05, 2004, 11:16:50 AM »
Too low,my tires are only 29" tall
« Reply #10 on: August 05, 2004, 02:43:29 PM »
Go Bigger tires ;D
Offline explosivo
  • 3157
« Reply #11 on: August 05, 2004, 03:29:33 PM »
Go Bigger tires ;D
I second that motion.
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #12 on: August 05, 2004, 06:02:54 PM »
What gears are you running now?
97 Sport
265/70-16s
2" lift
2.0 swap
95XL7
« Reply #13 on: August 05, 2004, 11:27:18 PM »
I'm running 5:13's now,but i want to increase a little to compensate for the taller tires and a little more acceleration off the line. But i don't want to go to high and ruin my highway speed either.
« Reply #14 on: August 06, 2004, 02:47:00 PM »
??? You got a V-6 with low 5 speed
gears, and you want more acceleration,
I think you should leave the Kick as is,
I only went to 5.83s for the off road
performance, I can pull 4.62s with 33
Swampers no problem with the Turbo,
You might want to re think this
