16 Valve Fuel Supply line
  • 1623 Views
Offline Captain_Jack
  • 80
  • I love YaBB 1G - SP1!
« on: February 23, 2004, 01:44:22 AM »
hat size fuel supply line do you use with the 16 Valve conversion.  My guess is 5/16".
Captain Jack
Re: 16 Valve Fuel Supply line
« Reply #1 on: February 23, 2004, 02:47:23 AM »
That should work fine, it's not like the
monster 16V burns much more fuel  :)
Offline SandRat
  • 18
  • So many toys! ÃÆâ€â„
« Reply #2 on: February 23, 2004, 03:22:28 AM »
Suggest that you have same size fuel return line as supply line. If you have a good fuel pump, you may overpower the fuel regulator with smaller return line.
Offline mrfuelish
  • 2862
« Reply #3 on: February 23, 2004, 05:13:30 AM »
my return line is a little smaller, the only prob. I had was after a couple of months the pump started to get louder and the idle was a little rich there was two kinks in the return line hose on top of the tank about a three inch long piece, so being by myself to fix it I pulled the tank out and used about 14'' of fuel line to replace the 3'' made a loop on top of the tank and used two clamps on each end it made it alot easyer to get the tank back up there and a lot better angle on the return line hose, also try to run your fuel pump ground wire all the way to your battery I hear that they might go out if you get a bad ground off of the frame!
