rear diff
rear diff
99tracker
14
I love YaBB 1G - SP1!
rear diff
January 21, 2006, 02:20:58 PM »
got the chance to buy an 86 sammy with a bad rear diff and a 89 tracker no engine for 500 can i swap out the rear third members in them
99tracker/k&n filter/rest is stock for now
wildgoody
8134
67
Re: rear diff
January 21, 2006, 05:51:24 PM »
Not without calling Petro Works,
Gary has a Hybread Sammy Tube
with a SideKick center, but you also
have to match the front diff gears if
you have 4WD
jason hutchison
495
5
ZUKIWORLD Staff
Re: rear diff
January 21, 2006, 07:17:28 PM »
Sky Manufacturing has hybrid housings also for your samurai.
http://www.sky-manufacturing.com/
541-736-3743
not bad at 225.00
couldn't the front R&P out of the kick be installed in the front sammi carrier? Then you would have matched gears.
although it might be cheaper to hit up your local pick a part yard and grab a differential from there. i used to pick up front diffs at a pick a part yard in oregon for like 125.00. check ebay too.
99tracker
14
Re: rear diff
Reply #3 on:
January 21, 2006, 09:46:45 PM »
ok thaks you guys ill look into that
purevil71
261
Someday when I grow up, I wanna be hardcore too!!
Re: rear diff
Reply #4 on:
January 22, 2006, 09:27:15 AM »
You could find two front trac/kick diffs with the same gears ratio and swap the gears out into the sami housing...
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
99tracker
14
Re: rear diff
Reply #5 on:
January 22, 2006, 01:41:06 PM »
could i swap both front and rear gears from the tracker into the sami
AJMBLAZER
2166
Your mom.
Re: rear diff
Reply #6 on:
January 22, 2006, 03:19:25 PM »
No, the Track/Kick rears are different. As shown above you'd have to get a custom Sami axle to use the Track/Kick rear chunk.
