clutch
  • 2987 Views
Offline beagle..t
  • 1239
  • 16
clutch
« on: October 09, 2011, 11:08:37 PM »
ok on super tight  budget cant really afford a new clutch kit was thinking of used  and then looked on ebay found a couple are they any good? anyone bought any from there should i go ome or something fancy or just throw used in for now till i can afford new i know that if i throw used in it may only last a bit then i got to do it again clutch is just starting to slip so could baby it for a little while
Re: clutch
« Reply #1 on: October 10, 2011, 06:21:24 AM »
If you're doing the work yourself - buy what every you want or can afford - it's your time you're throwing away.
If you're paying someone else to change the clutch, dig deep and get new and buy decent quality, nothing fancy, Exedy or similar - OEM isn't necessary - the labor cost to drop the transmission twice isn't worth the supposed saving - change the pressure plate, throwout & pilot bearings and rear main seal whilst you're in there.
Edit.
You didn't say what vehicle - if it's a cable operated clutch - check the adjustment - you may be able to squeeze a few more miles out that way.
« Last Edit: October 10, 2011, 06:23:05 AM by fordem »
Offline beagle..t
  • 1239
  • 16
Re: clutch
« Reply #2 on: October 10, 2011, 09:06:35 PM »
ooops sry 91 trackick if cable where would the adjustment be
Offline FBJR
  • 99
Re: clutch
« Reply #3 on: October 10, 2011, 10:38:21 PM »
Passenger side of the motor. Just follow the cable around the from the firewall to under the intake.
I think I had a motorcycle that was heavier!!
Offline beagle..t
  • 1239
  • 16
Re: clutch
« Reply #4 on: October 11, 2011, 06:11:02 PM »
ok thx
Re: clutch
« Reply #5 on: October 17, 2011, 05:53:56 PM »
Just bought a semi HD clutch for $81 delivered off eBay for a 95 Tracker.
http://www.ebay.com/itm/400174367417?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Good idea about the main seal fordem, what about the flywheel, should it be resurfaced?  Found a new one at Advanced Auto Parts for $90.
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Re: clutch
« Reply #6 on: October 17, 2011, 06:56:06 PM »
Always have the flywheel resurfaced/ground, when you put in a new clutch.
