what the ??????
  • 2080 Views
Offline Eden1
  • 73
what the ??????
« on: February 10, 2009, 04:52:07 PM »
Hi guys,I have a 92 tracker with a 8v.My problem is it wont start unless you spray fuel into the tb?there are 2 relays under the dash.( drivers side ) that are clicking and my iac valve is clicking too.if i unplug the iac it stops.if i chang the relays around it still clicks with the same harness,It runs fine after the spray of fuel??My engine light is on constant and wont throw any codes out???What is going on here????im lost...lol
Offline Sidetracker
  • 30
Re: what the ??????
« Reply #1 on: February 10, 2009, 04:56:07 PM »
It sounds like you need a new ecm (computer).
Offline Eden1
  • 73
Re: what the ??????
« Reply #2 on: February 10, 2009, 05:11:17 PM »
so why would it run fine after the startup?
Re: what the ??????
« Reply #3 on: February 10, 2009, 05:59:11 PM »
Those are the exact same symptoms my 92 Kick had when the ECM malfunctioned.  Sending you PM.
Offline Eden1
  • 73
Re: what the ??????
« Reply #4 on: February 11, 2009, 06:18:32 AM »
does this thing not give you a warning before it goes????
Re: what the ??????
« Reply #5 on: February 11, 2009, 07:11:26 AM »
If mine dropped me a hint in advance, I didn't get it.
