88 Samurai with 1.6l 16v EFI & 4" lift on 31s
  • 1130 Views
Offline tomgiboney
  • Total 4x4 Newb!
    • UpMyTech
« on: May 27, 2020, 09:19:59 AM »
I picked this up about a week ago.  I'm very new to the 4x4 world.  Anyone have any suggestions on things to check and replace as needed?
Thomas Giboney
1988 Suzuki Samurai with Sidekick 1.6l 16v engine and 4" lift with 31" Mud Claws.
https://photos.app.goo.gl/ahcR8GmXYTrbi7yq6
Offline JollyZuk
  • 284
Re: 88 Samurai with 1.6l 16v EFI & 4" lift on 31s
« Reply #1 on: May 27, 2020, 10:19:14 AM »
That is a nice looking rig.  Best advice is drive the rig and wheel it like you want.  If there are any deficiencies, you will find them.  You may find things that you want to fix or change just for own personal taste.  Anything right off the bat you are noticing that may need addressed?
1995 Sidekick JLX
OEM ROOF RACK!!!
« Reply #2 on: May 27, 2020, 06:21:49 PM »
I like to go through "new-to-me" vehicles with a "fine tooth" comb unless I'm familiar with their service history - full fluid change & all the "tune-up" items - engine oil & filter, transmission, transfer case & differentials, plugs, plug leads, distributor cap & rotor, air filter - tires, brakes, steering & suspension get an inspection and any required maintenance that the inspection indicates is required.
This may not happen immediately or all at once, but certainly within the first few months of ownership - because I do much of my own maintenance, these checks get done as week end projects.
Sure, it may cost you a few bucks, but it could also save your life - the last used vehicle I bought was missing the steering column-to-rack pinch bolt (trust me it could not have fallen out, some sloppy mechanic had removed it and not replaced it) causing the steering to be quite "vague" - it went in the general direction it was pointed in but wandered - that vehicle was also missing anti-rattle clips from the front disk calipers (again, these are not items that can fall out accidentally) - the weird part of this is the vehicle was actually purchased from a dealership who had been using it as a fleet vehicle - the same people whose lives were at risk, were the ones maintaining it.
Offline tomgiboney
  • Total 4x4 Newb!
    • UpMyTech
« Reply #3 on: May 29, 2020, 07:04:45 AM »
The shift lever.  Most definitely.  However, I've posted about that in another thread. https://www.zukiworld.com/forum/technical-discussion-beginner-repair/took-shifter-off-while-in-1st!-uh-oh!/
Thomas Giboney
Offline tomgiboney
  • Total 4x4 Newb!
    • UpMyTech
« Reply #4 on: May 29, 2020, 07:06:39 AM »
Good advice, thank you.
Thomas Giboney
