235's on sammy wheels fit Tracker ?
  • 1222 Views
Offline ZukiDuke
  • 40
  • Budget Beaters Rock
« on: December 08, 2006, 04:47:03 PM »
I have a set of 235's on stock 88 sammi wheels. Will these fit my 95 2dr with no rubbing, or should I put a set of coil spacers under it. It will just be a DD no trail use really, yet that is !
89 SideKick JLX 3spd Auto 5.13's Lockers, Homemade 3" BL , Digger Spacers, 31 " LTB's
95 LSI DD
95 Tracker G/F DD
88 Sami in the works
Re: 235's on sammy wheels fit Tracker ?
« Reply #1 on: December 08, 2006, 09:10:06 PM »
Go for it.
 ;D
crssvt
« Reply #2 on: December 08, 2006, 09:25:18 PM »
I have 235/75/15's on stock LSi wheels on my 94 2 door and have no rubbing issues.  My tracker is all stock other than the bigger tires.
-Chris
Offline sklope
  • 135
  • BUSHWACKER
« Reply #3 on: December 10, 2006, 08:07:01 PM »
I put 2.5 inch backspaced suzuki rims and 235/75/15 mud terrains on mine. Even with the backspaced tires and a 2 inch body lift, it rubbed a little on the bottom of the fender well. I used a air hammer and beat this area back a little (no more than a 1/2 inch). No more rub!
If you go with an all terrain or less aggressive tire it may not rub.
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
